Smokstak Down Under
Farmall Rear Tyres
this thread has 11 replies and has been viewed 3707 times
Old 09-26-2012, 05:40:56 AM
Irish Irish is offline
Question Farmall Rear Tyres
Does anyone know where I can get some 13.5 32 rear tyres from. I live in West Australia & had no luck here so managed to get hold of a guy in Brisbane - he can supply me with two brand new tyres for the measly sum of $2200.00 Each with out tubes & of course he would have to charge me freight? So by the time I get the rear tyres fitted it wouldn't be to shy of 5K. My old Farmall M would be so proud driving around with a lovely set of new boots but considering the price I think it would be cheaper to buy a complete tractor with tyres already fitted. Any suggestions or thoughts/advice would be appreciated.
Cheers Irish
Old 09-26-2012, 05:14:23 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: Farmall Rear Tyres
Does sound a bit steep, most row crop farmall M's here have 14.9/38 rear tires over here, the standard tread versions run on 30 inch dia rears. 32's here are used on the larger harvester/ combines and are considerably wider. Miller tire that specialises in vintage applications may have what you need, they advertise in most vintage tractor magazines here and probably have a web site if you Google it. F.J.W.
Old 09-26-2012, 06:41:48 PM
Norm Johnston Norm Johnston is offline
Irish, who ever that is quoting you that price is totally ripping you off, there has been a couple of companys had a run of 13.50 x32 tyres made in china and they were retailing around 750.00 each, not sure how many are left but I am sure there will be some .
Old 09-26-2012, 07:54:52 PM
ozfarm ozfarm is offline
harvest tyres where selling 13.50x32 tyres, get a grip tyres 1300 976 299 in perth had them
i was going to buy a set and put away in shed for when i needed em, word is , they are no longer in stock and the mould and rights have been bought by someone in indiana usa
was told his name is eric best, gary indiana
so whats happening now, i have no idea , looked on miller website before i went to the usa , with the idea of getting some to bring back in, seems they had nil stock also
Old 09-26-2012, 08:24:08 PM
bocephus_k6 bocephus_k6 is offline
38's on all 3 of our M's, 2 are running 15.5 x 38's and one will have either 16.9 or 18.4 x 38's....
Brian
Old 09-26-2012, 10:01:07 PM
FWurth's Avatar
One Millionth Post
The tire size on the M's in Australia, is it the norm for all or is it a metric measurement? Or are these tractors in a different wheel configuration thats different from our tricycle/ row crop here? Maybe export tractors were equipped diferently? Just trying to learn more about whats common there, thanks. F.J.W.
Old 09-27-2012, 01:01:30 AM
Craig Gillingham Craig Gillingham is offline
I'd say that Irish's Farmall M could be an Australian made (Geelong) model. I'm sure our tyre sizes are the same as any other imperial tyre sizes. There is a bit of history on the Geelong tractors here;
http://www.ploughbooksales.com.au/info/ihcW6/ihc-W6.htm
The Following User Says Thank You to Craig Gillingham For This Post:
Old 09-27-2012, 01:35:47 AM
FJW 13.5 x32 tire sizes were very common in Australia as at the time they were the larger cross section tyre of the late 30s and WD 40s,min,U and Farmall Ms along with early Aussie Chamberlains all used them, a lot of combines also used that size.some time in the 50s they started to use bigger tyres and 13.50 x32 were one to fall by the wayside,
The Following User Says Thank You to Norm Johnston For This Post:
Old 11-10-2012, 10:35:33 PM
Eric Best's Avatar
Eric Best Eric Best is offline
For what it's worth, I didn't buy the rights or the molds for the Harvest 13.50 x 32 tires. I hope someone did and is continuing to make them though because I still need several sets!
Old 11-11-2012, 08:23:07 AM
Ian Long Ian Long is offline
Hi Irish, I have bought a Farmall M wide front with 32" rear tyres and I also have a Row crop M with 38" Rear tyres. I am planning to take the 38's of the row crop M and put the on my wide front M as 32" tyres are not worth the hassle trying to get. i am using the row crop M for parts. I would sugest you get a set of farmall m 38" rims and centers and do the same. Regards Ian
Old 11-11-2012, 07:29:34 PM
thanks for clarifying that, info came thru a 3rd party
Old 11-20-2012, 02:40:11 AM
Thanks for the info Norm might get lucky & find some soon I hope.
Cheers Irish
---------- Post added at 02:40 PM ---------- Previous post was at 02:32 PM ----------
Ian , thanks for the common sense idea. I rekon it will be the way to go. I will have to get over to Victoria & pick up a complete set of 38"centres/rims & also for my "H" same again as it needs 28" centres/rims. The H has 26's fitted which are not sdtandard so eventually when I get the required bits it will be so much easier to getrear tyres for my Farmalls. Thanks again for your help & information.
Cheers Irish
Farmall H Rear Tyres Irish Smokstak Down Under 1 06-25-2012 09:18:12 AM
Tyres to oil NZ-Pete Fuels and Alternative Fuels 3 02-24-2012 02:59:18 AM
21 inch front tyres jamie davey Antique Farm Tractors 10 12-13-2011 03:47:32 PM
Free rear wheel weights....Farmall A G B Lee Antique Farm Tractors 1 05-11-2011 11:36:11 AM
One of a Kind Farmall Super A Rear Bucket Loader Dan O Antique Farm Tractors 5 04-20-2011 10:44:01 AM
