Mall model 8 Cork float? Should I gas it up?
this thread has 18 replies and has been viewed 2423 times
Old 01-05-2013, 07:52:01 PM
A S Price A S Price is offline
Default Mall model 8 Cork float? Should I gas it up?
I just got a mall 8, two man today. It has spark. The 88 year old original owner who sold it to me said it hasn't run in 56 years. Am I ok to put gas in it and try?? I see some other guys are saying about the cork float. I do not want to ruin this saw!!
Old 01-05-2013, 09:02:44 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: Mall model 8 Cork float?? Should I gas it up?
gas it up if you ask me as if that cork float is ruined then it would have been ruined from age. Many times i have made new cork floats and have sealed them with seal all or other type of super glue.
Old 01-05-2013, 10:23:57 PM
coyote62ny coyote62ny is offline
i have two disstons one kb6-ax and a DA-211 both have cork floats. i have been running them with no problems so far. but i am going to coat them with gas tank sealer this spring.i just shut the gas off at the tank and let them run until they quit this burns up all the gas in the carb and lines.so if you runthem dry i dont think you will have any problems. i would coat the float as soon as you can .
Old 01-06-2013, 01:10:52 AM
bigGURN's Avatar
bigGURN bigGURN is offline
It's the ethanol that's hard on the floats, get some stabil that neutralizes the fuel or go get high test fuel from your local air strip and you'll have no worries.
Old 01-06-2013, 08:47:50 AM
Great,Thanks for your help. I'm going to try today. I will put some ethanol treatment in the mix and se what happens!
Old 01-06-2013, 09:09:08 PM
Got it running..Takes quite a bit of pulling but after 53 yrs, I would too. I wonder if it takes regular bar oil in the trans, it has an automatic oiler.
This thing is a beast. I am 43 yrs old and am used to these new saws, but I am really enjoying the history of these old ones! Thanks for any help out there!
Old 01-07-2013, 04:17:29 PM
Exclamation Re: Mall model 8 Cork float?? Should I gas it up?
SAE 30 non detergent oil for bar oil. Use it liberally! Use high test gas, it will be easier on the engine, and alky levels are better regulated. I would remove the float and coat it with a good quality alcohol resistant gas tank sealer. I believe POR 15 and others make a good sealer. Lee pederson (a sponser here on the Stak), also sells a good sealer.
Old 01-07-2013, 05:20:40 PM
Great! Thank you for the info!
Old 01-08-2013, 10:00:09 PM
Seems the gentleman who owned this saw previously has already sealed the cork float. Those guys back than cared about their tools. All is great with this thing. Any one know where some new mall stickers are available?
I'm going cutting Saturday!
Old 01-09-2013, 12:36:38 AM
Default Re: Mall model 8 Cork float? Should I gas it up?
you may find mall decals on ebay or try brian at 1-720-260-0157 brian would be the one that would have nos decals.also north woods chain saw may have somthing 1-802-533-7133. if you dont get an answer when you call brian leave a message he will call you back he has a lot of old saw parts mostly nos.
---------- Post added at 11:36 PM ---------- Previous post was at 11:34 PM ----------
post some pictures of your saw we like pics videos are even better.
Old 01-10-2013, 08:26:19 AM
Great info! Thanks, I'm not very Pics and videos coming soon!
Old 01-10-2013, 10:53:15 AM
Here's a few pics
Name:	mall saw (3).jpg
Old 01-11-2013, 02:32:01 PM
mcbob mcbob is offline
Interesting photo can you snap a pic of the coupling between the gearbox and the clutch housing you may a a rather hard saw to find a late Model Mall 8 looks like a Mall 7 but aint as the Mall 7 has a bolt up on the clutch to gearbox housing
McBob
Old 01-11-2013, 08:15:48 PM
bigGURN's Avatar
Sugar Creek Supply makes reproduction decals, http:// http://store.chainsawr.com/c...upplies?page=6 or you can Google sugar creek supply
Old 01-12-2013, 10:39:16 PM
mcbob, I put up a video on U tube, Mall 8, 2 man saw. It def is an 8, seems pretty rare. It has a swivel type coupling. Makes it very easy to un- due, and transport. The clutch drum stays attached to the saw, and the drum stays with bar section when separated. A recoil starter would be just grand on this thing tho!
---------- Post added at 08:46 PM ---------- Previous post was at 08:44 PM ----------
Mall 8 2 man chain saw is the u tube thing actually.
Thanks big gurn, I shall check out that site for stickers!
---------- Post added at 09:10 PM ---------- Previous post was at 08:46 PM ----------
Here are the YouTube links:
http://youtu.be/VIb5vHpzm6w
http://youtu.be/3aPAM7H1k-c
http://youtu.be/Y1HmVgM3bBs
---------- Post added at 09:39 PM ---------- Previous post was at 09:10 PM ----------
Clutch shoes stay attached
Old 01-15-2013, 08:34:51 PM
The Mall 8 is indeed rare being the last of that group of two maners it has a different gearbox and bar and the Mall 10/11 style of helpers handle a great find and better still its a runner
McBob
The Following User Says Thank You to mcbob For This Post:
Old 01-17-2013, 07:24:11 PM
Mr mcbob,
I see alot of mall 7 that have a curved lower handle bar. My 8 seems to be the only one that has a straight bar. I see the older 7's even have recoil starters. It appears the the 8 is very unique and separate from the others, I wonder if it would be possible to put on a recoil starter or just leave it as is. One fellow even has a kick start on you tube. That would be handy. It is a bugger to keep running, I wonder if the cork float, new fuel, and not the greatest filter system is a symptom. It's still good clean fun to have and cut with this history.
Old 01-17-2013, 08:28:45 PM
bigGURN's Avatar
Any of the big mall saws with the no recoil start can be "kick started" you hook your tow on the notch for holding the knot of the starter rope and give it a spin. I've done it and people get a kick out of it.
Old 01-18-2013, 07:30:11 PM
I'll have to give that a try!! I have three sisters in Nampa, Boise area, they keep me posted on the shows and sales out in the big west.
Cork carburetor float Ronald E. McClellan Hit & Miss Gas Engine Discussion 10 01-29-2012 09:29:26 PM
Resealing a cork float? Peter Ruffle Small Air Cooled Gasoline Engines 5 07-27-2009 05:10:45 PM
Cork Carburetor Float mike kennedy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 07-07-2009 12:06:22 AM
cork float larry harding Antique Engine Archives 3 07-28-2004 08:30:17 PM
Cork Carb Float Kid Dynamo Antique Engine Archives 7 12-18-2000 08:12:29 PM
