Engine identification
this thread has 16 replies and has been viewed 3133 times
Old 03-28-2013, 04:08:20 PM
BigGoomba's Avatar
BigGoomba BigGoomba is offline
Default Engine identification
What is the manufacturer of this engine? What would it have originally been used for? How complete does it look?
I really like the look of the engine and think it would be fun to own one.
A photo is attached
The Following User Says Thank You to BigGoomba For This Post:
Old 03-28-2013, 06:08:27 PM
Ray Cardoza's Avatar
Default Re: Engine identification
vertical ideal?
Old 03-28-2013, 10:35:20 PM
bigGURN's Avatar
bigGURN bigGURN is offline
Not sure what it is, but that is for sure a modern carb, off a briggs, techumseh, or maybe even something japanese
Old 03-28-2013, 10:44:45 PM
BigGoomba's Avatar
The carb really doesn't fit with the engine that well does it. Wonder what the original one looked like. Do you think It is a more modern engine to? Still showing my green-ness. Don't know what to look at to age things. I am assuming that the flywheel/fan is cast which is a feature of an older engine isn't it?
Old 03-28-2013, 10:52:27 PM
Email NOT Working
As far as design, they'd call it an IOE (intake over exhaust)
or also an "F head" or "Pocket valve".
Similiar head/cylinder arrangement to lots of early motorcycles.
Like this:
http://farm9.staticflickr.com/8322/7...daf42c9d_z.jpg
Except your engine has an atmospheric intake valve rather than pushrod actuated. (and the flywheel is more homely. Looks like an air compressor style flywheel)
---------- Post added at 09:52 PM ---------- Previous post was at 09:48 PM ----------
If I had to guess, I'd say it's teens or 20s. But I have no idea what it is.
HD did make a stationary engine I guess, maybe others did too. There were LOTS of motorcycle makers back then.
The head & cylinder look motorcyclish to me, but not the rest of it.
Not saying the rest isn't original (I assume it is) just saying it was probably stationary rather than motorcycle.
Old 03-28-2013, 10:55:06 PM
Dan Baalman Dan Baalman is offline
ive had a couple of vertical Ideals, both defferent and nothing like this engine
Old 03-28-2013, 11:15:22 PM
bigGURN's Avatar
I wondered if it isn't a converted air compressor, as I have a compressor that looks similar. I hqve teased the wife I was going to make an engine out of it
Old 03-29-2013, 11:46:44 PM
oldschoolwisconsin oldschoolwisconsin is offline
That carb is a Briggs carb. Ive worked on one of those kind before.
Old 03-30-2013, 09:56:45 AM
aircoolengine aircoolengine is offline
That's a K series walbro Kohler carb. The engine Isn't an Ideal. I would agree that the flywheel is from a compressor.
Old 03-30-2013, 10:27:18 AM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
The whole thing could be homemade from scrap parts...
Old 03-30-2013, 11:23:16 AM
bigGURN's Avatar
Yep, I was just working on one of our the night before last, and thought now where else have I recently seen one of these, it does look like a walboro, all though B&S used some walboro carbs on engines in the mid to late 90s...
Old 03-30-2013, 12:15:55 PM
Lester Bowman Lester Bowman is offline
It DOES have compressor similarity's but I don't think it's a conversion.It is just put together to cleanly for a conversion.A few other pictures may help us at least determine if this is so..Back side pic?
Old 03-30-2013, 07:07:54 PM
BigGoomba's Avatar
Here is a pic of the other side.
Old 04-13-2013, 02:31:49 PM
BigGoomba's Avatar
I think I might have an idea at the possible origin of this engine but not the exact identity. I was at a museum last night and there were a bunch of old garden tractors and cultivators. A number of them were interesting contraptions where the motor sat inside a large metal front wheel and a good number of them had engines very similar to this one. The flyweel on this one may be a replacement though.
A will attach a photo of one that is similar. Not the same but similar design. Sparkplug is in different location for one thing.
Old 05-02-2013, 01:13:36 AM
BigGoomba's Avatar
I good friend of mine ended up with this engine and we are still scratching our heads about it.
Here are a few more photos
Old 05-02-2013, 01:15:55 AM
BigGoomba's Avatar
Another photo, can only upload I image at a time from an iPhone
Old 05-02-2013, 01:17:59 AM
BigGoomba's Avatar
One more photo. Any help identifying this engine would be greatly appreciated.
Engine Identification Trotts28 Unidentified Engines 5 09-13-2012 07:44:08 AM
Help with engine identification Lou Hit & Miss Gas Engine Discussion 9 08-22-2011 09:00:19 PM
Engine Identification, need your help R90SDaytona Hit & Miss Gas Engine Discussion 8 05-06-2007 10:53:28 PM
engine identification GM4106 Hit & Miss Gas Engine Discussion 12 10-30-2005 01:28:05 AM
Help with Engine Identification Craig Prucha Antique Engine Archives 3 02-08-2002 01:42:30 PM
