Brass Carburetor, what is it?
this thread has 5 replies and has been viewed 2070 times
Old 03-29-2013, 05:40:59 PM
BickerstaffSmallEngine BickerstaffSmallEngine is offline
Default Brass Carburetor, what is it?
Found this nice old carburetor but it has no markings whatsoever on it. Any idea what it might be?
ID:	161565   Click image for larger version
Old 03-29-2013, 06:59:40 PM
Restofire Restofire is offline
Default Re: Brass Carburetor, what is it?
I believe this to be a Kingston, it looks LIKE but slightly different than the Kingston 5 ball for the model T Ford, I know there were 4 ball versions and yours is most likely one of these. Paul
Old 03-29-2013, 07:10:18 PM
I was wondering if it was a Kingston. Do you know if they were marked anywhere that I might be missing?
Thanks for your help.
Old 03-29-2013, 07:45:02 PM
They usually have kingston cast in around where the body flares out to flange to the float bowl, the ones that don't have the name cast in have a brass tag at about the same location, I'm leaning toward 4 ball for this one, looks to be complete and in good shape, the choke lever is the giveaway that its a Kingston, but a handfull of manufacturers made carbs for the model T, Schebler, Carter, Holley, and a few others. Paul
---------- Post added at 07:45 PM ---------- Previous post was at 07:32 PM ----------
I meant the throttle lever, the idle adjuster with the set screw to hold it from turning out or in, thats a Kingston thing, and the cast bowl is earlier production, nice If its not model T it is old tractor, you might try posting pictures in the steel wheel antique tractor section, those guys may be more help then me. PJC
The Following User Says Thank You to Restofire For This Post:
Old 03-30-2013, 11:13:53 AM
Phil Johnson's Avatar
It looks too large to be Model 'T'. What is the throat size on it and the mounting hole spacing?
Old 03-31-2013, 09:59:48 AM
The mounting holes are 2 & 3/4". Throat is 1 1/4".
Odd Brass Carburetor Mark Shulaw Antique Marine Engines and Outboard Motors 5 02-17-2013 12:30:29 PM
Odd Brass Carburetor Mark Shulaw Maytag Engines and Collectibles 5 01-10-2013 06:42:10 PM
Brass Carburetor Float! Patrick62 Military MEP and Aircraft Gen-Sets 11 01-19-2012 07:56:10 PM
KT Brass Carburetor Molinegb Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 12-17-2010 09:16:12 PM
Old brass Carburetor? MotorPower Antique Marine Engines and Outboard Motors 2 09-14-2010 12:32:54 AM
