vintage unknown brand air compressor ... need help identifying.
this thread has 2 replies and has been viewed 2110 times
Old 11-09-2013, 01:04:37 PM
1awesomeseabee 1awesomeseabee is offline
Default vintage unknown brand air compressor ... need help identifying.
Hello all who view this. i bought this air compressor 10 years ago and it started making noise recently. I immediately shut it off to avoid damaging it further. I need help in identifying the manufacturer of this. i would very much like to rebuild it if there are any parts available for it. I have enclosed some pictures ... any and all information would very much be appreciated!!!: Dont know if the pics got uploaded and would appreciate it if someone write something here so I can try it at again. shrug:
Richard
ID:	179167   Click image for larger version
ID:	179168   Click image for larger version
ID:	179169   Click image for larger version
Old 11-09-2013, 01:35:53 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Default Re: vintage unknown brand air compressor ... need help identifying.
Your compressor appears to be a refrigeration compressor. The intake through the crankcase is what leads me to believe this. If that is the case, it was not made to have raw air pumped through it and the possible dirt & dust that goes with it. There doesn't seem to be any way of checking if there is oil in the crankcase. Even if there is oil in it, it could be pretty grungy if it has been run with no filter of some sort on that intake port.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-09-2013, 05:13:23 PM
Yes it's an ammonia compressor. The only thing you can do is pop the cylinder off and explore the guts. As mentioned, you'll find all sorts of grunge on the bottom of the crankcase.
NEED HELP!!! Identifying vintage air compressor pump by casting numbers 1awesomeseabee Farm Antiques and Collectibles 0 09-14-2013 12:08:44 PM
NEED HELP!!! Identifying vintage air compressor pump by casting numbers 1awesomeseabee Farm Antiques and Collectibles 0 09-14-2013 11:53:34 AM
Help Identifying Vintage Generator/Engine firestorm128d Generators & Electric Motors General Discussion 17 08-29-2012 12:57:19 AM
help identifying air compressor Irst Unidentified Engines 1 05-19-2012 07:04:43 AM
I need help Identifying my vintage 60' O & R Powered CanAm car stevster Small Air Cooled Gasoline Engines 5 11-02-2010 08:10:30 PM
