8N Ford Hydraulic Issues
this thread has 7 replies and has been viewed 1806 times
Old 01-17-2014, 07:29:34 AM
williamgrgn williamgrgn is offline
Default 8N Ford Hydraulic Issues
So here's the problem I have a 1948 8n ford blew the bull gear apart last year got a used rear end with awsome hydraulics but now they aren't working I changed the fluid and put on a new shifter boot when I put it together now the only way I can get it to lift anything is to flip the little switch under the seat and push it down any suggestions as to what's going on its a head scratcher
Old 01-17-2014, 09:41:48 AM
MCanady's Avatar
MCanady MCanady is offline
Default Re: 8n ford hydraulic issues
Maybe this will help. You most likely have a internal leak somewhere. Merton
Old 01-17-2014, 10:27:55 AM
Why would it work fine on the one side of that switch but not in normal conditions and what is that switch for under the seat on the right side?
Old 01-17-2014, 03:14:46 PM
MCanady's Avatar
William - The switch under the seat - I think you are asking about is the draft control selector. Draft control is for plowing or box blade work. If you plan on keeping the tractor you will need to purchase a service manual and a parts manual. Merton
Old 01-17-2014, 04:50:52 PM
Yeah I need to get one just the last 8n we had didn't give us these issues and this is just full of them
Old 01-17-2014, 07:54:56 PM
sqm1 sqm1 is offline
Default Re: 8N Ford Hydraulic Issues
If you removed the top cover make sure when it was reinstalled the long rod went back into the slot on the valve. This can be checked by removing the side cover that has the dipstick .You can also run the tractor with the side covers off to see if everything is moving.
Old 01-17-2014, 09:35:36 PM
Now one more problem I had with this salvage rear end I cannot shut off the pto the lever seems to be stuck
Old 01-18-2014, 01:53:00 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Possibly the linkages didn't get back in the right way when reassembled? If the pto lever doesn't operate then I would open the side cover and have a good look inside, the pto has to operate for the lift to work. F.J.W.
Cat 246B Skid Steer Hydraulic Issues High Voltage Garden Tractors and Mowers 12 04-09-2018 08:24:14 AM
1954 Ford NAA Hydraulic Question bubbaj Antique Farm Tractors 3 08-12-2013 11:29:32 PM
Ford 8N Hydraulic Pump Removal devin.beaudoin Antique Farm Tractors 7 07-24-2013 08:30:48 AM
Ford 900 series hydraulic problem rghanson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 04-09-2012 11:12:27 PM
Ford 9N Hydraulic Pump Repair drofnasd Antique Farm Tractors 3 10-16-2010 10:46:46 PM
