INT. M EXPERTS
this thread has 8 replies and has been viewed 1930 times
Old 06-12-2004, 04:40:48 AM
KEVIN CURRIE
Default INT. M EXPERTS
I am restoring McCORMICK-DEERING 1 1/2 hp MODEL M kerosene / gas engine & need a little help.I would like to know if someone can tell me if original skids were painted same color as engine or what was on them. K.C.
Old 06-12-2004, 06:25:46 AM
John Hammink
Default Re: INT. M EXPERTS
Kevin, the skids had the same color as the engine.
"Sixm" John
Old 06-14-2004, 02:02:30 PM
Rob Charles
From the couple of hundred M's I have seen(Afriend of mine and I have about 100 of them)The ign. models have some kind of varnish on the skids and when the wico model came out the skids were painted green.Most of the skids say "International Engine Kerosene 1 1/2 etc. HP" til 1923.Then they went to Mccormick-Deering Kerosene then the hp"Kerosene lettering is slanted.The 1 1/2 hp gasoline just says"Mccormick Deering 1 1/2 hp.Hope this helps. Rob
Old 06-14-2004, 09:29:51 PM
Bob C.
Rob,
I take it then that a 1923 1-1/2 hp igniter engine would have been just some kind of varnish over the wood (yellow pine on mine) and would have said "International Engine Kerosene 1 1/2 HP".
Is that correct?
Thanks, Bob
Old 06-15-2004, 10:22:45 AM
Rob Charles
I goofed alittle the hp comes before the "Kerosene" yes that would be about right on your 1923.Sometime in 1924 IHC changed most of their products to Mccormick Deering including engines and tractors.Rob
Old 06-16-2004, 12:55:00 AM
Andrew Mackey
I have a early 1919 3 HP IHC M (100th engine made that year according to IHC) With it's original skid work. It has the undershot igniter (single bearing) The skid on this unit was painted black, with the lettering done in white. This engine was not mounted on a cart. The engine was painted in its original IHC green.
Old 06-16-2004, 01:46:44 PM
Rob Charles
Andy, Is that diffinately black paint?Varnish turns black with age.I have an original skid that looks a little black but it's just the old varnish.Rob
Old 06-16-2004, 10:57:09 PM
chuck kaufman
I've got a wico M 1 1/2 hp thats black Iwas told it powered a vacume pump for milking
Old 06-17-2004, 01:13:26 AM
Andrew Mackey
Skid was definately painted black. I had to remove and replace center support board, and it was black on all surfaces. I had to have the board custom made at a local lumber-mill as the piece was dimensional lumber - not the cheap undersized stuff they sell today.
Any car experts here Barnbikes Antique Autos and Trucks 7 07-03-2017 12:45:38 PM
For the IHC M experts roland servais Antique Engine Photos 3 07-24-2010 12:56:42 PM
Need Help From I.H.C. Experts Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 12-05-2009 04:49:54 PM
Looking for IHC Experts Colin Rush Hit & Miss Gas Engine Discussion 5 08-22-2007 03:02:56 PM
