Barn fresh model Y
this thread has 67 replies and has been viewed 5184 times
Old 07-10-2014, 06:56:48 PM
Rigaman Rigaman is offline
Default Re: Barn fresh model Y
Im missing the check ball disk too in my check valve.
So I gotta find something to stick in there. It must be some kind of washer or gasket that the ball seals to, and doesnt suck all the way up to the top.
Old 07-10-2014, 07:46:03 PM
vinceostapowich vinceostapowich is offline
Could you use a modern plastic pickup tube?
if you didnt want to go that route ,you could make something up to sit inside and on top of the check ball and then the pickup tube itself would hold the washer down.
Old 07-10-2014, 07:51:42 PM
Ahhh I see its a different animal than a press fit check tube.
Im guessing youd have to fab a very small piece of metal up to sit inside
Name:	check ball .png
Old 07-11-2014, 11:47:07 AM
I think it is press fit. I saw a thread where someone had theirs taken apart. I can't find it though. I'd like to see what the parts look like in decent shape. So I can fabricate the piece I need.
I'm almost ready to get this engine back together and see how it runs. My intake valve had some pitting in it. But right under where it seats. So it shouldnt effect it. I'll leave it for now.
I was at a garage sale and the guy had a valve grinder for sale. I thought.. When would I ever use that!? But it was $100 and I almost bought it.
Old 07-12-2014, 05:39:06 PM
GaryH GaryH is offline
After removing the end piece with the screen in it. Put the pipe tube in a vice, carefully, then hacksaw a couple of grooves about 1/8" deep so when the check ball goes all the way up fuel can flow through the pipe with no restriction.
I have seen them from the factory like this.
Gary
Old 07-13-2014, 10:40:41 AM
Ok awesome. That should do it. Cool thanks!
---------- Post added at 10:40 AM ---------- Previous post was at 10:01 AM ----------
I got a 3/16 steel ball bearing.
Seems like a good size. Anyone have one of these apart to measure the bearing?
Old 07-13-2014, 12:06:22 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
It is smaller than 3/16.
Old 07-21-2014, 07:31:36 PM
Brian Lynch's Avatar
How are you progressing with your model Y?
Barn fresh... Greg DeKeyzer Steam Stationary Engines, Traction Engines 30 02-11-2013 08:36:53 PM
Barn fresh FH Nate Bolduc Small Air Cooled Gasoline Engines 6 12-26-2012 08:34:44 PM
Barn Fresh? K L Workman Hit & Miss Gas Engine Discussion 20 03-13-2010 04:47:58 PM
Barn Fresh!! Daniel Dorece Hit & Miss Gas Engine Discussion 11 03-30-2008 08:46:45 PM
first IHC Barn fresh 1 1/2 hp M Eric McKenna Antique Engine Archives 5 09-21-2004 12:34:49 PM
