Repainting a really badly painted engine
this thread has 4 replies and has been viewed 1711 times
Old 07-28-2004, 10:13:27 PM
Bob R.
Default Repainting a really badly painted engine
Got a 1 HP Famous that runs great, but really looks bad. The paint job is terrible and pinstriping is even worse. Should I take it apart to do the paint job right? Let me know what you think. Am only hesitating because it starts and runs so easily.
Old 07-28-2004, 10:44:43 PM
Ralph Leonard
Default Re: Repainting a really badly painted engine
Bob, that engine is well worth the effort to do it right. And its easier to deal with the individual parts.
I use cheap oven cleaner from the Dollar store. Occlude the parts in plastic to keep them wet for an hour or two and hose it off. A pressure washer works even better. Two cans and a pair of plastic gloves will easily do an engine that size.
Ralph in NC
Old 07-29-2004, 07:27:53 AM
Randy
I just repainted my 1-1/2 KELLER, without taking it apart, because it starts & runs so good. Taping it off wasn't TOO bad, but taking the tape off, was! I folded the ends, so I could find them, but the tape would break & NOT cooperate! I HATE IT WHEN THAT HAPPENS!!! I've repainted a couple other engines, without taking them apart & they've turned out pretty good. I used a wire-wheel & paint remover, to get off as much of the old paint as possibe. You gotta go with what works! BE SAFE...rubber gloves & goggles should be used! GOOD LUCK!!!
Old 07-29-2004, 07:50:26 AM
Bill Schaller
the odds are that the engine was originally hand painted after assembly, so that would be the correct way to restore it.
Old 07-29-2004, 08:37:56 AM
Bruce Sutton
When you take them apart you can do a better job on the re-finish plus your going to find other little things that you didn't know about that need attention. My thoughts.
TFD, new owner. Engine is painted blue? Lurch Wisconsin Engines 8 03-04-2016 11:48:09 AM
Onan 6.5NH-3CR/16004P Arcing badly from inside generator housing, engine end mronkar Onan Generators 13 11-01-2011 09:48:47 AM
Wico EK and Painted Engine DaveTexas Magnetos, Ignition Coils and Spark Plugs 5 04-28-2011 05:09:44 PM
Repainting a running engine BobM Hit & Miss Gas Engine Discussion 5 02-10-2008 08:45:00 PM
Repainting the Engine... Jeffrey Paint Shop 1 11-06-2002 03:17:44 AM
