BW air compressor in shop
this thread has 4 replies and has been viewed 1485 times
Old 12-26-2014, 09:20:29 PM
3VO 3VO is offline
Default BW air compressor in shop
I have an old tank mounted "BW' compressor that makes air. I read that these compressors use a pressurized oil feed from the truck engine but I am not going there. I suspect this compressor was used for years without one because the copper oil feed line is crimped off.
There seems to be no easy way to tell how much it oil it has and what is too much. Unless I get better advice I will just give it my best guess. There is nothing to loose here.
3v0
Old 12-27-2014, 12:43:53 AM
Default Re: BW air compressor in shop
borg warner did make compressors for truck brake systems and some larger units for service trucks
Old 12-27-2014, 11:03:50 AM
Ed Noli's Avatar
Ed Noli Ed Noli is offline
Bendix Westinghouse did make self contained units with splash lubrication and oil level indicator. The remote mounted units had engine oil pressure fed to the rear cover and oiled through the crankshaft and a drain to the main engine. Not sure how these would last with a splash system. Ed
Old 12-27-2014, 04:36:09 PM
3VO 3VO is offline
I guess I need to clean it up to see if I missed a sight glass or some other sort of indicator.
Old 12-27-2014, 10:43:41 PM
SteveK SteveK is offline
If there is a drain hole plugged off maybe you could screw pipe into it then some clear tubing to see your level.
On the level
My new Shop M&WJOE Hit & Miss Gas Engine Discussion 19 01-23-2014 06:56:38 PM
1920's or 30's Circus Wagon with small city built inside,Blacksmith Shop,machine shop Jim Martin Scale Model Engineering 2 04-15-2013 11:01:46 AM
Machine Shop Wood Shop Collectors in Michigan and Ohio antiquemachinery Farm Antiques and Collectibles 1 03-30-2013 12:12:58 PM
Leo compressor: Trying to identify a small compressor unit MattFretwell Unidentified Engines 1 02-27-2012 07:01:50 PM
What does your shop look like? Chris J Hit & Miss Gas Engine Discussion 124 10-12-2010 09:01:56 AM
