Briggs WA
this thread has 16 replies and has been viewed 1710 times
Old 02-24-2015, 10:30:57 PM
Alan Wakefield Alan Wakefield is offline
Default Briggs WA
I broke in a Briggs WA today. What a beefy thump'm motor. I didn't have a crankcase breather so I made one out of a pipe nipple and the top of a round finned FH breather. Had a lot of blow by out that set up. Does anyone have the right breather or similar extended breather they would want to part with? I possibly may have another problem if the oil want to pump up the tube. Any thoughts?
Al
Old 02-25-2015, 11:24:19 PM
Default Re: Briggs WA
I'm going to give this a try. Going to use the same breather set up but I stuffed the 8 inch tube full of the steel Chore Boy scrubber. Followed that up with a screen and a pin to hold everything in place. Seems to be a nice breathable baffle.
Old 02-25-2015, 11:37:33 PM
Junkologist's Avatar
Al,
Don't ever use steel scrubber or wool material in a breather. It will rust and the particles will end up in the crankcase. You don't want rust and small steel particles floating around your crankcase and in the bearings. Use copper material in your breather and you will be good to go.
Mike
SmokStak member #146
Old 02-26-2015, 02:27:20 AM
Fifty7ChevyNut Fifty7ChevyNut is offline
is there a briggs engine that you would consider in trade for your WA?
i also like the sounds of the big briggs engines. i have a bunch of zz, a couple k, two or three Q, and i think 2 Rs.
thanks for time.
don
Old 02-26-2015, 09:04:56 AM
Junkologist, thanks for steering me straight on that steel scrubber. I'm glad I posted my misguided brainstorm.
Don, thanks for the options but I think I'll hang onto it and enjoy it for awhile.
Old 02-26-2015, 11:15:37 PM
The scrubber I used ended up being stainless so it probably would have been OK. I still removed it and used copper. Softer stuff should there be a problem.
Old 02-27-2015, 12:25:04 AM
mr allen, not a problem, if you never ask, you will never know. if you have a manual, send me the part number, i will look at my other engines and see if they were used on more than one engine.
don
Old 02-28-2015, 09:07:31 PM
Restofire Restofire is offline
Alan, you stated that you "had a lot of blow by" in this engine you were braking in. Not knowing how complete of a rebuild was performed, I am tempted to think that maybe one of the piston rings got installed incorrectly ? There are alot of variations of piston ring designs, and it can be difficult to see the differences between 2 sides of the same ring. Just a thought, not trying to say you don't know what you are doing. How about showing us a picture of the seldom seen WA ?
Old 03-01-2015, 11:46:01 AM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
Hey Allen,
I read the first entry you made to mean you are getting a lot of oil
coming out the top of the home made breather tube as engine runs. I had a little Nelson Bros engine that did the same thing when a section of pipe was used as a breather, just as you have happening now. I think an original Briggs / Stratton breather will solve your problem of oil coming out the top of the breather tube.
The Following User Says Thank You to Everett Hayden For This Post:
Old 03-01-2015, 12:10:52 PM
The blow by problem wasn't from the cylinder. The problem that I was having was oil pumping up my homemade breather tube. I have packed a
copper scrubber into the 8 inch pipe nipple to use as a baffle to keep oil in the bottom. I then followed that in with a screen and then installed a thru pin to keep everything in the tube from falling back into the botton. I've haven't tried it out yet so the verdict is still out. Here's pics of the engine, breather and sparkplug after initial break in. Look pretty good.
ID:	219821   Click image for larger version
ID:	219822   Click image for larger version
The Following User Says Thank You to Alan Wakefield For This Post:
Old 03-01-2015, 12:27:27 PM
Everett, I've been looking for an original breather but they seem hard to come by. My plan B is to use a breather off one of the smaller engines and mig it to a black pipe nipple. Seems like that would be a good option if I can make it look good enough.
Old 03-01-2015, 12:43:20 PM
Hey Alan,
Nice engine, nice job. That spark plug looks just great as far as color, with no oil showing on it. Here are a couple pictures of my own WA. Got it right
here, off the Stak's classified's section. I put this one on a small set of engine trucks finally. Too awkward an engine for me to just horse around anymore. Ha!
Name:	Brigs Stratton WA #444 002 (1200x800).jpg
ID:	219828   Click image for larger version
Name:	Brigs Stratton WA #444 003 (1200x800).jpg
ID:	219829   Click image for larger version
Name:	Brigs Stratton WA #444 005 (1200x800).jpg
ID:	219830   Click image for larger version
Name:	Brigs Stratton WA #444 017 (1280x853).jpg
The Following 3 Users Say Thank You to Everett Hayden For This Post:
Old 03-01-2015, 01:06:06 PM
Great patina on that engine. Nice original!
Old 03-01-2015, 01:16:25 PM
bart price bart price is offline
Alan I will get you a breather. Maybe see you in Portland Bart
Old 03-01-2015, 01:46:46 PM
gambitace71 gambitace71 is offline
hi,the breather you have on your WA should work fine.Depending on the year.you have the proper breather.In the early 30s briggs changed breather and went to the larger breather.I have a W, Q and a couple of model Rs with your style of breather and there is no problem with them blowing oil.It appears that you have to much crank case pressure For some resson.nice looking engine.thanks ken
The Following User Says Thank You to gambitace71 For This Post:
Old 03-01-2015, 02:02:00 PM
Thanks Bart. I hope to see you there.
Old 03-08-2015, 07:01:20 PM
RLee's Avatar
RLee RLee is offline
nice engine
Briggs: Advice on Briggs ZZ & I pistons GreyWulf Hit & Miss Gas Engine Discussion 3 12-25-2014 10:31:05 PM
Briggs I Signal Corps Genset/ Briggs 6 Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 9 01-17-2013 12:38:02 AM
Briggs in a bucket, my new Briggs FB Jonathan Widelo Small Air Cooled Gasoline Engines 9 01-01-2013 12:56:59 PM
Briggs parts interchange not in Briggs book Ken Karrow Small Air Cooled Gasoline Engines 4 09-17-2011 12:50:16 AM
Original Briggs pump?+1943 briggs NPR6 41Briggs Small Air Cooled Gasoline Engines 4 12-30-2009 11:21:28 AM
