Antique Army Generator with Briggs ZZ
this thread has 16 replies and has been viewed 3463 times
Old 03-26-2015, 08:18:20 PM
Capt Ron Capt Ron is offline
Default Antique Army Generator with Briggs ZZ
I have been fortunate to get this old military surplus (?) generator that had been used at a remote cabin in the 1960's. It hasn't been run since the 1980's (after power was brought in to the location) and now I would like to restore it. It doesn't have an identification plate but a side plate has numbers on it. ZZ 308144 176255 020 015 Im guessing a Briggs and Stratton (ZZ) but what year and is it old army surplus? This will be a great project and I want to do it right. Thanks in advance for any suggestions or help.
ID:	221949   Click image for larger version
ID:	221950   Click image for larger version
ID:	221951   Click image for larger version
The Following 3 Users Say Thank You to Capt Ron For This Post:
Old 03-26-2015, 08:53:41 PM
mschreiber mschreiber is offline
Default Re: Antique Army Generator
april 44. type 308144, s/n 176255, look here.
http://www.flywheelers.com/pages/BobLearned/mdate2.htm
The Following User Says Thank You to mschreiber For This Post:
Old 03-26-2015, 09:00:19 PM
Ahhhh, thank you very much. I'll be looking for parts soon.
Old 03-26-2015, 10:26:33 PM
RobW RobW is offline
The generator might be Leland. Not very many manufacturers made the square ish frames.
The Following User Says Thank You to RobW For This Post:
Old 03-27-2015, 07:18:28 AM
WildIrishman52's Avatar
WildIrishman52 WildIrishman52 is offline
I have the screen guard for the belt and pulleys. I bought an engine on the frame years ago minus the generator. It is a ZZ. 6hp.
Joe
Old 03-27-2015, 10:37:09 AM
RSCurtis RSCurtis is offline
I had one of those several years ago that I bought at Jacktown. It was in very nice shape and ran perfectly. However, be aware that it's not a true 120V generator- each leg is 60 volts.
The Following User Says Thank You to RSCurtis For This Post:
Old 03-27-2015, 11:31:53 AM
Thanks for that bit of information. I'm not an electrical wizard so im going to have to research exactly what that means. I recall it running regular light bulbs when it worked but I can't remember how many. I won't be using it to actually do anything, more just restoring it as a project. Do you have any connections for parts I may need?
Old 03-29-2015, 12:13:58 PM
graflex graflex is offline
That's a PE-73 Gen set. WW2 vintage. The engine should be a Briggs model ZZ.
Some where around here I have an original manual for one of these.......
Old 03-30-2015, 02:01:33 AM
Thanks for letting me know that, it would be an interesting story to hear how a USA WW 2 generator came to be powering a cabin in the 50-60's in British Columbia, Canada. I would love to buy a copy of your manual. Also, any tips of parts suppliers? A replacement fuel tank or re-pop is definitely needed. I would like to research parts before starting an overhaul, otherwise it might just best be left in "as is" condition.
Old 03-31-2015, 01:12:01 AM
Fifty7ChevyNut Fifty7ChevyNut is offline
Default Re: Antique Army Generator with Briggs ZZ
I am thinking it is a pe 75. I have a few of the manuals, and about 6 of the generators.
Weighs in at 340 lbs if i remember right. Should have two wooden handles on each side. Take them out, put in the ends and it is a 4 man lift.
The Following User Says Thank You to Fifty7ChevyNut For This Post:
Old 03-31-2015, 01:41:27 AM
I believe you are right, a PE-75 as it looks exactly like the ones I've seen on YouTube. I'll look for a dolly to wheel it around on. Hoping to find a few parts, clean it up, and get it running for no other reason that I love doing that sort of stuff.
Old 03-31-2015, 06:43:28 AM
MoRo's Avatar
MoRo MoRo is offline
I'd consider using it. Military gen sets, of that era, were designed to put their rated output into the wires all day long, not just "surge" rating with a significantly lower "run" rating. Pretty much bullet proof.
Old 03-31-2015, 09:51:49 AM
K-Tron K-Tron is offline
I had the luxury of picking up a NOS PE-75 two summers ago. Mine has all of the original decals, bells & whistles that it would have had from the factory, including many NOS parts in the toolbox, and a decommissioning manual which shows you how to destroy the unit if an enemy is approaching! I didnt have to put much into mine to get it working again, maybe 30 hours of cleaning/lubricating/regreasing the engine and generator, making sure everything worked like it should. After that it started up in one pull after sitting for 70 years! Its a really neat looking piece, but its quite finicky during operation. I despise those two piece flo-jet carburetors, and bought a slew of Marvel Schebler TCX carburetors for it, I just havent had the chance to actually rebuild one and fit it to the unit. The Leland 2500 watt generator head has no internal voltage regulator, so forget about running any modern electronics with it. Ive run mine for a while running lights and an electric heater, and boy does it get loud under load! You would think that a 2200rpm 6hp engine wouldnt use too much fuel, but boy was I wrong, its a very thirsty engine. Memory tells me it would run 40 minutes to 1 gallon of fuel. I have a thread on smokstak about it, and a few videos on youtube. If you need any pictures or anything feel free to ask,
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 03-31-2015, 11:28:41 AM
Chris
how do i find videos of it?
Old 03-31-2015, 11:31:32 AM
Thanks Chris, very interesting to hear what you had to say. I think for now I'll just enjoy cleaning it up and getting it running as I love projects like this. I think if I can get a fuel tank, muffler, and maybe a carb kit that will be all it it needs as the rest is just cosmetic. It sat neglected for a very long time in a generator shed close to the ocean so it might be questionable if it's worthwhile. I'll check out your YouTube videos and thread. I will be sure to ask if I have any questions while tackling this project.
Old 08-03-2016, 04:59:30 PM
johnnyrock70 johnnyrock70 is offline
Awesome. I have the same green colored ZZ. And our serial numbers are not far apart. Strong runners these are! My muffler is marked 'Nelson'.
(Pics attached) also, my video can be seen on youtube (briggs ZZ engine cold start)
ID:	259554   Click image for larger version
ID:	259555   Click image for larger version
The Following User Says Thank You to johnnyrock70 For This Post:
Old 08-05-2016, 07:13:15 PM
The generator should be a 2500 watt Kurtz and Root.........I had an identical unit, minus the engine, given to me. I tore the generator apart and found that some idiot had run the pulley end bearing dry until it froze........then kept running it so the armature shaft spun in the bearing! I pulled the entire armature out, arc welded the massive groove in the shaft, straightened it and turned it back down to size on my lathe. I then installed brand new bearings in both ends and that generator is now powered by my Listeroid diesel as a standby unit for my house.
They made good, rebuildable stuff back then.
The Following User Says Thank You to George Andreasen For This Post:
Need parts for Army PE-245 generator Robert Ward Military MEP and Aircraft Gen-Sets 5 10-21-2014 07:45:12 PM
Army Generator Tom Rowe Generators & Electric Motors General Discussion 6 03-02-2011 01:13:08 AM
Onan army generator 6JB 53E ? elfinwood Onan Generators 6 05-10-2007 08:21:43 PM
help with LAUSON ARMY GENERATOR COREY Generators & Electric Motors General Discussion 1 03-25-2004 02:14:14 AM
1941 Army generator Calvin C. Generators & Electric Motors General Discussion 0 09-08-2003 04:07:29 AM
