Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Newer Model coil on older model 92?
this thread has 2 replies and has been viewed 1027 times
Old 09-21-2015, 09:05:49 AM
racevw112 racevw112 is offline
Default Newer Model coil on older model 92?
Will a coil off of a late 30's model 92 engine work on a late 20's model 92 engine?
Also, are all the coils on these engines made by Bosch?
Thanks,
Lyle
Old 09-21-2015, 03:08:19 PM
gambitace71 gambitace71 is offline
Default Re: Newer Model coil on older model 92?
hi,yes all of the 92 coils will interchange.thay are all bosch coils.
Old 09-22-2015, 11:49:53 AM
The 92 type held the record for the longest production run of an internal combustion engine, without a major design change. All parts will interchange between them! The only changes were the size and design of the fuel tanks and starter pedals! As long as you kept them in the proper fuel/oil mix, they practically ran forever!. it usually doesn't take much to get them running!
Model "BUZZ" coil ZZZAAAPPP for a model engine Paul Spence Magnetos, Ignition Coils and Spark Plugs 5 02-22-2015 10:36:08 AM
Earlier model Maytag 72 vs. older??? enginesilo Maytag Engines and Collectibles 2 05-22-2008 02:36:01 AM
Considering older Onan, which model? walexa07 Onan Generators 4 03-17-2007 10:49:38 AM
Newer to hobby, need help with B&S Model Number pvtschultz Small Air Cooled Gasoline Engines 8 12-23-2006 10:21:25 AM
Kohler Model D Manual, Older (1923-25) Rusty Fingers Kohler Generators 14 11-15-2005 11:58:12 PM
