Columbus Mckinnon chain hoist problem.
this thread has 12 replies and has been viewed 1201 times
Old 10-17-2015, 08:03:14 PM
1936JDB 1936JDB is offline
Default Columbus Mckinnon chain hoist problem.
I picked up a really nice Columbus Mckinnon lever style aluminum chain hoist at the local pawn shop. The trouble is that with any load on it, it ratchets, but doesn't hold. The pawl is external, and clicks with authority. I'm going to tear into it when I get a minute, but I thought someone here might have some insight, and advice.... Thanks.
NOT mine, but just like this one... http://www.ebay.com/itm/ALCOA-1-1-2-...YAAOSwyQtVnwzK
Old 10-17-2015, 09:36:59 PM
Tim0477 Tim0477 is offline
Default Re: Columbus Mckinnon chain hoist problem.
In addition to it having the up and down selector on the handle, does it have a large knob with "free chain" and "operate" marked on it? The large knob should be where the handle meets the body.
Tim
The Following User Says Thank You to Tim0477 For This Post:
Old 10-17-2015, 09:43:11 PM
Not that I can find. Just the toggle on the lever, and the pawl. I did notice that it's a Model B, if that means anything to anyone....
Old 10-17-2015, 09:46:31 PM
If I remember correctly, the B has dual clutch disc. Remove the two screws on the handle cover, should be a slotted nut with a cotter pin thru it. Adjusting instructions are on the inside of the cover you removed. See what happens.
The Following 2 Users Say Thank You to Pat Barrett For This Post:
Old 10-17-2015, 10:04:36 PM
THANKS, that's just the kind of thing I was hoping to hear.
---------- Post added at 09:04 PM ---------- Previous post was at 08:51 PM ----------
I thought I'd done pretty well for $35 till I tried it out. I was sure that something of it's quality would be repairable though.
Old 10-17-2015, 11:38:16 PM
Sunnyside Sunnyside is offline
And make sure there is no oil anywhere near that clutch mechanism-on mine there is a little warning tag to that effect , put there for the millwrights to ignore..............
The Following User Says Thank You to Sunnyside For This Post:
Old 10-18-2015, 12:03:38 AM
I see that type of chain hoist from time to time, but never really gave them much thought, always seemed like it was a special application thing because if mounted too high you could not reach the lever. So what am I missing? How are these used?
Old 10-18-2015, 02:22:46 AM
Like a regular chain hoist plus a lever arm Dal.
Doc
Old 10-18-2015, 09:08:17 AM
Mostly used as a come-a-long.
Old 10-18-2015, 09:42:55 AM
We used them a lot at the factory I used to work for. Most guys regarded them as safer than cable come alongs. They used them upside down too, so the handle was on the low end. You also don't have the cable spooling up on a drum causing "jumps" and "falls'.
The Following User Says Thank You to 1936JDB For This Post:
Old 10-18-2015, 11:13:20 AM
I like oldstuff I like oldstuff is online now
I sold a chain heat treating system and other hardening systems to CM. A first rate company and I'd bet parts are available should the clean and adjust routine be inadequate. Get it right, as an overhead hoist is the last thing you want to fail. If it's no longer reliable, trash it.
Old 10-18-2015, 12:02:12 PM
Are you the guy with the plant on the river in Bay View? Always seemed like a mysterious 'throwback' operation as I passed it........
Old 10-18-2015, 12:11:20 PM
Nope not me. I stay out of bay view as the area inhabitants make my skin crawl.
Gantry hoist or A Frame Hoist treasurechest Machine Shop and Tool Talk 7 12-20-2011 02:13:52 PM
Remington chain Problem Sky Chain Saw Collectors 2 02-28-2009 06:00:08 PM
New chain hoist ? TheToolman Machine Shop and Tool Talk 6 11-04-2008 07:59:41 PM
Columbus hoist engine info wanted caterpillarman Hit & Miss Gas Engine Discussion 3 03-01-2007 12:51:19 PM
Wiring switch on an old Budgit chain hoist. Repulsion motor? paul t Generators & Electric Motors General Discussion 5 03-10-2006 08:32:43 PM
