John Deere E 1-1/2 hp hit and miss cam and governor bushing size? HELP!
this thread has 5 replies and has been viewed 963 times
Old 12-02-2015, 07:06:21 PM
timeickschen timeickschen is offline
Default John Deere E 1-1/2 hp hit and miss cam and governor bushing size? HELP!
I'm looking for the inside diameter of the cam and govenor bushings for a John Deere E hores and a half hit and miss engine (are they both the same?). I know they can easily be purchased but being a Machinist, I'd rather make them myself. Also, what is the purpose of the knoch in the end of the bushings? I'm new to this hobby and this is my first engine restoration. Any info on this is greatly appreciated.
Old 12-03-2015, 07:37:03 PM
Gilbert_Bates Gilbert_Bates is offline
Default Re: John Deere E 1-1/2 hp hit and miss cam and governor bushing size? HELP!
Forget right off hand, but I think you'll find the cam and governor shafts to be worn and hence, undersized. I just used my shafts as reference to make some new bushings. The cut outs are for oiling, point them to the inside and up.
Old 12-03-2015, 08:33:51 PM
How much clearance should there be between the shafts and the inside of the bushings? A few thousands?
Old 12-05-2015, 03:02:01 PM
Scott's Avatar
Scott Scott is offline
The part numbers for the bushings are the same, also fits the 3hp .
The Following User Says Thank You to Scott For This Post:
Old 12-06-2015, 12:17:16 PM
midpw midpw is offline
I'll betcha that Lightning Magneto (sponsor) will have what you need.
Or Jim White.
Bruce in Saint Ignace
The Following User Says Thank You to midpw For This Post:
Old 12-06-2015, 02:00:35 PM
Or Jim White.
It just so happens that Lightning Magneto is a half hour from me in Ottertail Minnesota. I'll check him out. Thanks Bruce!
John Deere Governor Help trailrl Hit & Miss Gas Engine Discussion 12 12-11-2015 09:56:41 AM
Wood bushing for unstyled A John Deere ironhorse446 Antique Farm Tractors 4 03-03-2015 11:59:21 PM
1952 John Deere A Tire Size? C. Lambert Antique Farm Tractors 5 07-19-2011 11:27:55 PM
1/2 size John Deere engine Reeves13hp Scale Model Engineering 0 11-05-2009 01:08:04 PM
John Deere E exhaust size Mike Monnier Hit & Miss Gas Engine Discussion 3 09-06-2009 11:03:17 PM
