Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Ford CL20 SkidSteer
this thread has 2 replies and has been viewed 1329 times
Old 02-21-2017, 09:58:08 PM
Merc300SD Merc300SD is offline
Default Ford CL20 SkidSteer
I have a 1978 Ford CL20 Skidsteer. Runs great! However, one of the axles twisted and broke. Its a long shot but is there anyone out there that has an axle for it? I am weighing options of repairing the old axle but that is a questionable undertaking.
Joe
Old 02-22-2017, 10:15:26 PM
s100 s100 is offline
Default Re: Ford CL20 SkidSteer
I've seen this happen before on the same model of loader. I'm guessing that there's something marginal about those axles, or else the quality control or metallurgy is slipshod. The last one I saw was on a tenant's machine. He tried to have the axle "repaired" (against my advice) and it was a complete waste of time and money. If the axle itself is not up to the task, any repair most certainly won't be as strong as the original metal and will fail in short order.
The tenant ended up spending something like $700 for a new axle, plus the time to install it. That's about the value of the machine, methinks, but he did what he had to do. From my foggy recollection there isn't anything particularly special about that axle, just a shaft with a taper on one end and keyways. What I would do if it were mine, I would simply make a new axle from a good quality steel. If you do not have the ability to do this, I'd say find a good machine shop to make one for you.
Good luck!
Old 02-23-2017, 06:38:10 PM
old sparky old sparky is offline
contact Herman Mfg at507-553 5296 they made a lot of them I supplied the prototype
looking for Ford BB clutch housing, info´s of running a Ford engine on gas GTfan Antique Farm Tractors 0 04-20-2015 09:37:24 AM
Bobcat skidsteer fuel problem Hawk624 Farm Antiques and Collectibles 7 04-05-2015 10:33:52 AM
Steam-Era 2013 Featuring Ford and Ford Equipment cerwin Canada 1 07-07-2013 09:02:17 PM
International Skidsteer Fred Van Hook Antique Farm Tractors 4 12-01-2008 03:41:08 PM
