Embrace points problem Briggs WMB
this thread has 7 replies and has been viewed 459 times
Old 02-24-2019, 12:15:47 PM
tjg4036 tjg4036 is offline
Default Embrace points problem Briggs WMB
Hello. I have a Briggs wmb when turning the engine over the push rod for the points is not moving at all not only is it not moving the points the rod is not moving at all. I’m new to these motors what hits the points push rod that moves them that I’m just not seeing or understanding.
Old 02-24-2019, 12:38:18 PM
Junkologist's Avatar
Default Re: Embrace points problem
The little pushrod is probably already pushed up and stuck. If you can’t just pull it up out of its hole with your fingers, it’s probably stuck. They seem to swell up sometimes and get stuck. Pull it out with a pair of pliers and lightly sand it until it moves freely. There is just a cam on the crankshaft that moves it, so nothing complicated down there. The points remain open for most of the revolution of the crank, only momentarily closing, so the pushrod only drops once every revolution of the crankshaft.
SmokStak member #146
Old 02-24-2019, 01:06:47 PM
Please excuse typo on title. I took it out and put new one in it doesn’t seem to move at all
Old 02-24-2019, 01:27:28 PM
dkamp dkamp is online now
eMail NOT Working
Make sure the bore isn't somehow obstructed, and that there's not a broken off piece jammed in the bottom end...
Old 02-24-2019, 01:27:32 PM
Try putting pressure on the pushrod to make sure it is bottoming out in the hole. If it doesn’t bottom out and touch the crankshaft, it won’t move. There is only a small indentation in the crankshaft that allows the pushrod to drop. The indentation could also be filled with dirt and gummy oil and not allowing the pushrod to drop.
Old 02-24-2019, 01:45:43 PM
ulgydog56's Avatar
pour some marvelous mystery oil down the port and soak, can't hurt...
Old 02-25-2019, 10:42:44 AM
batrider batrider is offline
It doesn't move much at all and only closes briefly so easy to miss this.
Old 02-26-2019, 05:55:54 AM
Philipagri Philipagri is offline
Have you checked the length of the pushrod? I've had the same problem with a Model A, When I freed it the rod was still not pushing up and checking in the manual it was worn too short. I tried getting a new one but the part number has apparently been transferred to more modern Briggs and these are much smaller so I'm now looking at making one. Mine should be 1inch long.
Strange Points Related Problem With a VH4D tima Wisconsin Engines 15 08-26-2018 08:41:15 AM
Onan 6.5nh Points Problem and Points Replacement and Adjustment mvimpvm Onan Generators 18 11-28-2017 12:11:05 PM
Onan 6.3NHL-3CR/16013P Points problem. Fred McNeill Onan Generators 0 09-03-2015 06:02:47 PM
Onan 5.0 CCK points wiring problem texrock Onan Generators 16 10-27-2010 08:23:53 AM
Kohler 10hp K241 spec 46520D points plunger problem bass3139 Garden Tractors and Mowers 5 03-17-2010 07:59:46 PM
