Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
How to Build Foundry Patterns
this thread has 2 replies and has been viewed 818 times
Old 01-31-2018, 10:06:51 AM
old iron shops old iron shops is offline
Default How to Build Foundry Patterns
I'm going to show you my wood pattern making process this is for beginners buy building a foundry pattern for an angle plate that I'm going to have cast in this one we build the wood pattern out of pine an excellent pattern makers wood.
https://youtu.be/PUx4_sR5aAg
The Following User Says Thank You to old iron shops For This Post:
Old 01-31-2018, 01:41:17 PM
Default Re: How to Build Foundry Patterns
If you are making a replacement part, don't forget to add a shrinkage factor to your pattern! I think, for cast iron, in the area of about 10%? For bronze a little less?
Old 02-02-2018, 08:34:25 AM
yes it will be accounted for . nothing worse than bad fitting part thanks .
Anyone Else Build Foundry Patterns old iron shops Wood Shop and Projects 14 05-05-2018 04:21:30 PM
Patterns, Who's Got What? Sad Iron Hit & Miss Gas Engine Discussion 34 01-12-2013 04:50:44 PM
Patterns on ebay Don Blausey Scale Model Engineering 5 02-03-2010 04:13:06 PM
Foundry Patterns Craigs list Pa. JeffK Machine Shop and Tool Talk 2 05-15-2009 04:45:57 AM
