Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
Heat Treating Instructions Needed
this thread has 3 replies and has been viewed 1107 times
Old 02-01-2018, 11:51:25 PM
DustyBar DustyBar is offline
Default Heat Treating Instructions Needed
I need to harden a 2" diameter by 1/8" disc and need the maximum hardness possible. I heated them red hot and dropped them into water but they didn't get real hard. One is D2 which is air hardening. Do I just heat it red and let it air cool? The other one is 440 Stainless which I understand is oil quenched. Do I also heat it red and drop it in something like 30w motor oil? Do I have to hold it at red heat for a while first? I'm looking for maximum hardness for wear resistance.
Old 02-02-2018, 08:37:56 AM
Default Re: Heat Treating Instructions Needed
Got a smart phone? Download this free app from the ASM. It's a guide for heat treating many metals and is gospel.
https://play.google.com/store/apps/d...e.heattreaters
Old 02-02-2018, 04:51:53 PM
Larry Rusch Larry Rusch is offline
Here are a couple of instructions from presumably reliable sources.
http://www.admiralsteel.com/reference/sstltech.html
https://www.speedymetals.com/informa...aterial11.html
Old 02-02-2018, 11:17:55 PM
Both of those materials are to be hardened at about 1900 degrees F.
The stainless is to be oil quenched, but the D2 is an air hardening material that apparently can be oil quenched.
A "red heat" is a pretty loose term, for a number of reasons:
First, a "read heat" can be anything from 500 to 950 C (932F - 1742F).
Secondly, your eyes and brain may vary in their interpretation of what "red" is.
Since you have already unsuccessfully attempted to harden your parts, you really do need to normalize them before attempting to harden them again.
Another reason to dig into the specs suggested by previous posters.
Pete Stanaits
The Following User Says Thank You to Pete Spaco For This Post:
Jaeger Cement mixer instructions needed bugzilla Farm Antiques and Collectibles 9 10-24-2010 07:41:21 PM
Oiling instructions needed for Empire D30 steamlee Steam Stationary Engines, Traction Engines 2 02-01-2009 10:21:58 PM
Heat treating piston rings?? IronCity2006 Hit & Miss Gas Engine Discussion 2 10-05-2008 12:12:48 PM
Heat treating tools JoeCB Blacksmithing and Metallurgy 3 08-22-2008 08:03:15 AM
Mag charger instructions needed Norm Antique Engine Archives 1 11-14-1999 04:31:08 PM
