Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 82 Adjustable Rod
this thread has 6 replies and has been viewed 1280 times
Old 05-01-2018, 12:38:31 PM
Turbo's Avatar
Turbo Turbo is offline
Default Maytag 82 Adjustable Rod
I just bought this 82 and upon disassembly to clean the parts I found this interesting modification. Someone took some time and slit the crank pin end. Then made a clamp out of some round stock bending it around the rod. It has shims in between and when a shim is removed, the clamp is tightened by the nut on top. Very ingenious!
ID:	309614   Click image for larger version
ID:	309615   Click image for larger version
ID:	309616   Click image for larger version
The Following 4 Users Say Thank You to Turbo For This Post:
Old 05-01-2018, 04:45:29 PM
Kevin Weis Kevin Weis is offline
Default Re: Maytag 82 adjustable rod.
Thinking that would throw it off balance some but maybe doesn't really affect it at all? repair looks pretty old. Guess even back in the day they didn't have a lot of 82 repair parts left on hand after they went to the 92's.
Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 05-03-2018, 05:53:57 PM
Turbo's Avatar
Default Re: Maytag 82 Adjustable Rod
Yes it looks like they did what they had to do to keep it running! I have seen some cobbled up farm repairs before, but someone really put some thought and time into this rod! I disassembled, cleaned and replaced all the gaskets. Then coated with 50/50 linseed oil and mineral spirits. It looks pretty nice, but unfortunately someone dropped it and cracked the base at one time. I squirted in some gas and it took off. Now I think I will build a skid and make it a shelf queen.
Old 02-19-2019, 11:16:21 PM
CODY K's Avatar
CODY K CODY K is offline
Wow that is pretty crazy. I would throw that rod in the scrap bin. It is severley compromised, its a castrophie waiting to happen!! Look at it, they drilled a hole right through the center, then broke off the top outside flanges!! The only thing holding it together is the bottom flange, if it happens to come apart, you are going to be looking for alot more parts then just a rod!!
Old 02-20-2019, 01:19:57 AM
CODY K's Avatar
Old 02-21-2019, 12:16:41 AM
ulgydog56's Avatar
back in the day you did what you had to do to keep stuff running and get your moneys worth, smart then, stupid now....
Old 02-21-2019, 09:05:46 PM
Motormowers's Avatar
Relax the thing would prob be fine. It ran all that time they put it together. Worst thing that could happen is there's one less spittin and fartin bug killer in the world.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
B&S 4hp adjustable jet question tapkoote Garden Tractors and Mowers 6 04-18-2017 09:57:41 PM
Adjustable Hitch Nick Lingg Horse Drawn Equipment 5 03-07-2017 11:01:37 PM
IHC LA - No adjustable governor? jeeperforlife Hit & Miss Gas Engine Discussion 4 08-06-2010 10:21:16 PM
Adjustable resistance 2.5 LK onandan Onan Generators 13 01-01-2009 03:00:59 PM
Adjustable Reamers Rex Piekarczyk Machine Shop and Tool Talk 18 12-21-2008 10:50:16 PM
