Go Back   SmokStak > SmokStak® General Discussion > Smokstak Canada
Smokstak Canada For Canadian Smokstakers to meet, greet and have local discussion.
Smokstak Canada
6/3 Solid Aluminum Wire?
this thread has 9 replies and has been viewed 834 times
Old 06-21-2018, 02:37:06 PM
Default 6/3 Solid Aluminum Wire?
Hi everyone, Is it true up in Canada that 6/3 solid aluminum wire is still being sold? https://www.homedepot.ca/en/home/p.e...000663706.html
Robert
The Following User Says Thank You to Railroads For This Post:
Old 06-22-2018, 12:38:14 AM
Charlie1925 Charlie1925 is offline
Default Re: 6/3 Solid Aluminum Wire?
Railroads; And don`t take 110 elect. cord with ground pins up there, They don`t have outlets for them. I found this to be true in the campgrounds. They do sell adapters. Roger Weinhold AKA Charlie 1925
The Following User Says Thank You to Charlie1925 For This Post:
Old 06-22-2018, 07:53:10 AM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
I think there is a mistake in the Home Depot listing - the description reads in part; "Superior electrical cable with copper electrical wire for residential electrical wiring projects. 6 AWG Romex SIMpull NMD90 with Freeze Flex includes 3 copper conductors and one ground wire."
Aluminum household wiring is not commonly used here.
You find ungrounded receptacles in very old houses sometimes. The campground mentioned was risking being shut down if the authorities discovered the unsafe receptacles in commercial use.
Canadian electrical codes are very strict.
The Following 2 Users Say Thank You to Jack Innes For This Post:
Old 06-22-2018, 08:13:00 AM
"Superior" might in fact be a brand name, not an indicator of characteristics.
Doc
Old 06-22-2018, 03:55:22 PM
Hmm, Someone told me the 2 prong to 3 prong adaptors are outlawed in Canada? Your electrical codes are very similar to ours here in the states.
Robert
Old 06-22-2018, 04:43:25 PM
Vanman Vanman is offline
I believe that they still sell those here in the States, don't they? Just have to 1) verify that the center screw is indeed grounded, and 2) actually use the center screw with the adapter.
The Following 2 Users Say Thank You to Vanman For This Post:
Old 06-22-2018, 05:24:00 PM
Oldtech Oldtech is offline
Ya. Codes are quite interchangeble in Canada/ U.S. Any campground with 2 prong outlets is from the 60's. As to Aluminium wire, it can be used for underground and entrances, but not in the building. They allowed it's use back in the 70's but problems arose.
The Following User Says Thank You to Oldtech For This Post:
Old 06-22-2018, 07:29:44 PM
Keith, Yes, Those adaptors are still widely available here in the states. There are still houses with only 2 wire outlets and thus they are a required.
Oldtech, The same happened here with the Ally cable. It was introduced in 1965 and was withdrawn in 1975 or thereabouts. Although stocks of it were still used into the 1980's or thereabouts till all of the Ally cable was used up.
Robert
Old 06-26-2018, 04:44:52 PM
Bill Sherlock Bill Sherlock is online now
I keep several of those 2 prong to 3 prong adaptors on hand for when I might need them. I don't worry about grounding them. There's lots of 2 prong extension cords currently being sold out there so grounding can't be that important. I've never had an issue with grounding anyway, except when winter road salt on a block heater plug would cause a GFI circuit breaker to trip. Placing an ungrounded 2 prong to 3 prong adapter in line with the block heater cord would solve that problem.
Bill
Old 06-27-2018, 07:46:19 PM
GFCI has it's place but I consider them evil. They don't like my electric mower either.
Robert
Service Wire Used to Supply Power to House (Aluminum/Copper) JT240Z Onan Generators 93 12-02-2017 09:33:17 AM
Aluminum Wire Legends: Troll Onan Generators 7 01-31-2017 11:39:26 AM
Cloth Covered Solid Core Primary Wire Tom Adkins Hit & Miss Gas Engine Discussion 21 09-03-2013 08:48:47 PM
Aluminum piston, aluminum cylinder? NAR Scale Model Engineering 9 03-11-2008 02:02:27 AM
Webster wire solid or multistrand? Eric McKenna Hit & Miss Gas Engine Discussion 4 07-01-2005 09:51:08 PM
