UNKNOWN Brass Carburetor with Brass Updraft Tube
this thread has 2 replies and has been viewed 777 times
Old 07-20-2018, 10:42:31 AM
Jason Dahm Jason Dahm is offline
Default UNKNOWN Brass Carburetor with Brass Updraft Tube
I recently acquired this at an estate sale. Does anyone know what make or possible application it had? It's a pretty unique setup...note the offset brass coupler in the tube. Thanks in advance.
ID:	314459   Click image for larger version
ID:	314460   Click image for larger version
ID:	314461   Click image for larger version
Old 07-22-2018, 09:11:22 PM
carbking carbking is offline
Default Re: UNKNOWN Brass Carburetor with Brass Updraft Tube
It appears to be some variant of a Zenith model S. If the bowl cover is original, and readable, there should be some additional model identification there.
As to exact application, it is probably possible, but the value of the time involved to do the identification would greatly exceed the value of the carburetor. There were LOTS of applications for the Zenith type S.
The offset adapter was quite common 90 or so years ago.
Every carburetor company had a better idea, and made aftermarket carbs for a number of applications. As the physical shape of carburetors in that time period differed significantly, adapter were necessary to physically adapt a specific carburetor to a specific application.
The most common offset adapter was used to adapt virtually anything other than the original Marvel to 1926~1929 Buicks.
Jon.
The Following User Says Thank You to carbking For This Post:
Old 09-08-2018, 11:33:41 AM
ChipTosser ChipTosser is offline
Looks like a hot water manifold inline, for cold weather.
The Following User Says Thank You to ChipTosser For This Post:
Unknown Brass Carburetor (Schebler?) taaviw126 Carburetors, Mixers, Fuel Pumps and fuel delivery 4 10-03-2017 09:04:42 PM
Brass Unknown Carburetor, Curved Flange RustySteele Carburetors, Mixers, Fuel Pumps and fuel delivery 0 06-18-2017 08:09:45 AM
Unknown Brass Carburetor Car or Motorcycle?? Jason Dahm Antique Autos and Trucks 1 04-03-2014 08:39:05 PM
Bending Brass Tube Junkologist Antique Engine Archives 14 11-28-2004 06:31:57 PM
