Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
Broken Anvil
this thread has 8 replies and has been viewed 1291 times
Old 08-02-2018, 01:25:30 PM
Steve Kunz's Avatar
Default Broken Anvil
I saw this anvil on Craigslist. https://stlouis.craigslist.org/grd/d...659777540.html
I have never seen one that was broke this bad. What would it have taken to break it? Bad casting?
ID:	315449   Click image for larger version
Steve Kunz
Old 08-02-2018, 01:31:52 PM
Big Bird Big Bird is offline
Default Re: Broken Anvil
If it belonged to my one of my brothers...
Probably a rubber mallet
My guess would be a casting flaw.
The Following 2 Users Say Thank You to Big Bird For This Post:
Old 08-02-2018, 01:53:23 PM
MCanady's Avatar
MCanady MCanady is offline
I have one at home just like this anvil. No I did not break it. It was broken over 50 years ago by someone else. My father told me it was broken on a very cold morning. Merton
The Following User Says Thank You to MCanady For This Post:
Old 08-02-2018, 02:00:57 PM
Harry's Avatar
Don't overlook the possibility that it might have been in one of those shows where they place a powerful charge underneath and set it off to see how high they can blow them into the air!
https://www.youtube.com/watch?v=aA71cXy_PhA
(See our Terms of Service)
The Following 5 Users Say Thank You to Harry For This Post:
Old 08-02-2018, 02:37:25 PM
Target Driller Target Driller is online now
Hence the term "Blowing the Anvil"
What a good dose of FFFF black powder will do!
The Following User Says Thank You to Target Driller For This Post:
Old 08-02-2018, 10:06:24 PM
Turbo's Avatar
Turbo Turbo is offline
That reminds me of what my grandfather used to say about people who were prone to breaking things. "That man could break an anvil".
The Following 2 Users Say Thank You to Turbo For This Post:
Old 08-03-2018, 10:38:16 AM
ronm ronm is offline
My Uncle used to say about my cousins "Give 'em an anvil & they'll tear the horn off of it".
Smokstak member #442
The Following 2 Users Say Thank You to ronm For This Post:
Old 08-03-2018, 06:09:57 PM
Dustin D Ehli Dustin D Ehli is offline
Wouldn't be that hard to break a smaller one really if doing heavy work with a Stryker working with tools in the Hardy hole.
That's why I've made a striking anvil to eliminate heavy work on my real anvils, it's also lower down too so easier to work off of with a sledgehammer.
Also ones that aren't a solid wrought base are made from forge welded pieces, could of broke at a bad weld
Having a blast preserving the past.
My Youtube Channel
The Following 2 Users Say Thank You to Dustin D Ehli For This Post:
Old 08-04-2018, 10:25:30 AM
Yes, I'd go with the "made in several parts" theory. A bit surprising that the face (top plate) is broken off so squarely. I bet some owner ground the end square and continued to use it.
If you saw it on craigslist, then I might assume that you are in the market for an anvil. I'd skip this one if you want one to do real work. You need a hardy hole and a pritchel hole.
----Unless you are sentimental.
These are often referred to as "doorstop anvils".
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
anyone know what this anvil is gmciver Blacksmithing and Metallurgy 4 01-31-2016 04:04:49 PM
Anvil Case441 Machine Shop and Tool Talk 6 09-21-2014 07:54:23 PM
Would You Hit This Anvil? Steve Page Blacksmithing and Metallurgy 8 02-07-2013 11:05:27 PM
anvil fix johndeere60orchard Blacksmithing and Metallurgy 6 10-19-2012 08:51:59 PM
Another anvil ID Chester5731 Blacksmithing and Metallurgy 0 10-27-2010 08:29:36 AM
