Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Upright
this thread has 10 replies and has been viewed 1498 times
Old 09-14-2018, 12:15:30 AM
ThisGuy ThisGuy is offline
Default Maytag Upright
Hello,
Long time lurker and finally signed up. The information on this site is awesome, thanks to everyone who shares. I just picked this up and I'm looking for any info on it and thoughts on where to start and where to go with it. The serial # is 78903.
Thanks for your time.
ID:	318727   Click image for larger version
ID:	318728   Click image for larger version
ID:	318729   Click image for larger version
The Following 2 Users Say Thank You to ThisGuy For This Post:
Old 09-14-2018, 10:01:40 AM
OrgWayne OrgWayne is offline
Default Re: Maytag Upright
1937 is the year , I'm pretty sure , check shopdog sam , and a few other on you tube, they rebuild them pretty nice, good luck , mine is a 1927
Wayne
Old 09-14-2018, 02:03:20 PM
Ray Cardoza's Avatar
they use a 1/2 pipe thread spark plug autolite 3095 or a champion X.
Old 09-14-2018, 03:53:30 PM
bobeg bobeg is offline
1920 was year made, Nice little upright
Old 09-14-2018, 07:37:35 PM
Thanks for the input. I haven't had time to look at it past unpacking it, wiping it down and taking a couple pictures. All input and suggestions on where to start are appreciated.
Old 09-15-2018, 10:02:46 PM
Kevin Weis Kevin Weis is offline
Nice find! Start by cleaning and sealing tank. Then disassemble and clean carb and check valve in pick up tube. Be very carefull if you remove flywheel and bearing. Bearing tabs are very fragile. Only tighten mounting bolts hand tight!
Kevin
Old 09-16-2018, 06:34:40 PM
Thanks Kevin, I will start there. I will get a spark plug and gasket set headed in my direction. What should I do for the exhaust? How about a buzz coil, should I get one of the new ones I see on Ebay when I look up maytag motors?
Old 09-17-2018, 08:09:22 PM
ThisGuy, the set up for the exhaust would have been either an approximate 10" long pipe with the cast iron pancake muffler screwed on it or a flexible tube that has an aluminum pipe fitting cast on it for the engine end and pancake muffler on outboard end as above. The flexible pipe set up is rare as hens teeth (even just part of it). There is a nice reproduction of the muffler itself on eBay. I think the pipe is 1/2" NPT. Be carefull handling the castings, they are fragile. A model T buzz coil will work fine for these and are inexpensive. Hope this helps. Kevin
Old 09-19-2018, 01:35:54 PM
Thanks again Kevin.
Old 09-21-2018, 03:40:46 PM
Are Marvin McCullough's manuals still available? I picked the twin manual up on Ebay at the beginning of the year and it's great. I could definitely use one for the upright and my buddy wants the 92 manual. I don't see any on Ebay and I don't remember who the seller was I got it from.
Old 09-22-2018, 12:30:06 PM
Yes they are last I checked. PM me & I'll get you his phone number
Upright Maytag Rod KubotaDiesel Hit & Miss Gas Engine Discussion 0 12-09-2014 11:02:52 AM
Upright Maytag John Herald Maytag Engines and Collectibles 3 08-08-2014 07:12:57 AM
upright Maytag rodue Small Air Cooled Gasoline Engines 0 08-27-2012 08:33:36 PM
Maytag Upright Brian.P Maytag Engines and Collectibles 10 06-13-2011 10:08:05 AM
Maytag Upright Help Brad Franken Antique Engine Archives 0 05-31-2003 10:07:56 AM
