Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Model 92 Quit Running
this thread has 7 replies and has been viewed 867 times
Old 09-29-2018, 05:16:23 PM
Bperk Bperk is offline
Default Maytag Model 92 Quit Running
Maytag model 92. First timer here. Tore her all apart, striped their down to bare metal, new paint and all new gaskets. Slapped her back together and she started with about 4 or 5 kicks. She ran for about 2 minutes and quit. Now she won’t fire back up. Kicks over just fine. Seems to have ok spark and black oily fuel drips on the ground through the exhaust. Anybody have suggestions on what to check first?
Old 09-29-2018, 06:09:58 PM
Pat Barrett Pat Barrett is online now
Default Re: Maytag model 92 quit running
Pull the carb and examine the check valve , could have a piece of trash in it, or stuck.
Old 09-29-2018, 08:18:57 PM
Thank you for the advice Mr Barrett. I will check it out.
Old 09-30-2018, 10:18:01 AM
Arlie Levy Arlie Levy is offline
Another thing to check is needle valve position. Take the little lever off the needle valve and turn the needle all the way in to the right. then reinstall the lever all the way to the right. Sometimes the needle is open too far and flooding the engine. A lot of the ones I work on have this problem. You only have the 180 degree range to work with. Good luck.
Old 09-30-2018, 11:32:40 AM
Kevin Weis Kevin Weis is offline
Check also the spark plug for dirt or carbon between body an electrodes. Kevin
Old 09-30-2018, 11:35:58 AM
Thanks guys. I will fiddle with her as soon as I can and repost
Old 09-30-2018, 12:33:38 PM
Huntkng Huntkng is offline
When I posted someone suggested I blow and inhale into the intake on the "Carb" (fuel mixer). They said that if the poppet is working correctly you should be able to hear it rise and fall....I don't know if that helps but, there it is! Good luck.
Old 10-04-2018, 06:44:54 PM
Thanks for the advise! I did blow on the carb and it seemed to be sticking so I took it apart and cleaned it and she fired up on the 2nd kick. I certainly appreciate those who gave advise.
Onan Microquiet (J) Quit Running and Won't Start Kanoona Onan Generators 77 09-07-2018 01:21:43 PM
Engine 15.0 JC quit running cranking limiter popped suntreemcanic Onan Generators 34 12-01-2015 02:06:43 AM
1/2 scale running Maytag model 92 rodue Scale Model Engineering 1 10-15-2015 11:28:10 PM
Maytag Model 92 - Erratic Running Francis Maytag Engines and Collectibles 6 11-30-2010 10:00:56 AM
Help needed on getting Maytag Model 31 running Toby(NC) Maytag Engines and Collectibles 5 10-02-2007 07:39:58 PM
