Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Engine RPM
this thread has 1 replies and has been viewed 626 times
Old 10-22-2018, 03:05:50 PM
noeleo noeleo is offline
Default Maytag Engine RPM
I have several Maytag Model "92" engines and one Model "72D". What should the RPM be for each type? Just wanting to play with the governors and make them sound about the same. I have checked the 72 and adjusted it to 1500 (it was just over 2000 when I first checked). Anyone know the recommended RPM?
Thanks for your help.
Old 10-22-2018, 04:34:08 PM
Exclamation Re: Maytag Engine RPM
The 72-D twin should turn at about 1200 RPM no more. Running at 1500 or faster is a sure way to blow the soft solid bronze rods out of it in a hurry! Same goes for the 92 type singles - a soft bronze rod won't last too long, if run faster than designed for long. The 92s turn even slower -about 1050 to 1100 RPM, as per the Maytag service manual, SAE 30 Non-detergent oil or TCW-3 OIL only - no synthetic or one mix lubricants!
For Sale: Antique Maytag 1934 wringer washer with gas Maytag engine Charley K Antique Washing Machines 1 07-24-2018 07:01:02 PM
Maytag engine ronny p 148 Maytag Engines and Collectibles 27 12-21-2015 11:32:56 PM
First Maytag Engine engine-alan Maytag Engines and Collectibles 9 02-03-2011 07:02:56 PM
How much is a Maytag 92 engine washing machine worth with no engine and missing a leg Hit and Miss kid Maytag Engines and Collectibles 13 10-13-2009 07:20:22 AM
Maytag engine age Andrew Mackey Maytag Engines and Collectibles 10 12-02-2007 12:49:16 PM
