Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag model 19 odd kill switch. Original?
this thread has 9 replies and has been viewed 1116 times
Old 11-06-2018, 09:26:08 AM
Tony Glaser Tony Glaser is offline
Default Maytag model 19 odd kill switch. Original?
I just picked up a model 19 original engine. I started to disassemble it before taking pictures but the magneto plate has two wires pruning through the mag backing plate. Is this possibly a way to kill the engine? It doesn't have the steel rod the runs to the spark plug but just could be missing as the engine was missing a few parts. Also does anyone know the correct part number for the kick pedal? The one that looks like the early twin with two 45 degree bends. The serial number on the flywheel is 725167. Thanks for any help/opinions.
Old 11-06-2018, 10:30:05 AM
Clement Rook Jr. Clement Rook Jr. is offline
Default Re: Maytag model 19 odd kill switch. Original?
tony, i dont know anything about the wires on your backplate but the kick pedal # is
S295. the magneto upright used wires going to a switch for the engine shutoff.
The Following User Says Thank You to Clement Rook Jr. For This Post:
Old 11-06-2018, 02:56:57 PM
By the serial number, your engine was built in June 1936.
Old 11-06-2018, 06:31:34 PM
Clement, is the offset pedal from the early twins the same as the 92 model 19? Thanks
Old 11-06-2018, 08:23:00 PM
Turbo's Avatar
Turbo Turbo is offline
As far as I know the only engine to use that kick pedal is the model 19.
---------- Post added at 06:23:00 PM ---------- Previous post was at 06:20:50 PM ----------
Do a search on this site, there are a couple good threads on the 19 with part number info on the kick peddle assembly
Old 11-07-2018, 08:30:29 AM
tony ,the twin uses # S319 foot pedal. i dont have a twin with that pedal to compare to my model 19. it may be the same with a new part # sorry i cant be more helpful
clement
Old 11-09-2018, 09:00:36 AM
Clement, do you have a part number for the segment gear? Also I know it is a long shot but I could really use one to complete mind. Thanks again for all the help. -Tony-
Old 11-12-2018, 12:37:52 AM
Kevin Weis Kevin Weis is offline
I don't think that kill switch is original. Nothing in the Maytag parts catalogs shows such a switch set up.
Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 11-12-2018, 10:29:41 AM
tony,the model 19 uses the S295 foot pedal & S296 starter segment
twin uses the S319 foot pedal & S317 starter segment
hope this helps
clement
Old 11-13-2018, 09:25:55 AM
Kevin I agree with you the more I dug into it it looks like it was done along time ago. The lead coming from the coil had a wire soldered to it about 4 inches away from the coil.
Clement thanks for checking for me! I'll be looking for a segment gear and putting an ad here in the classified ads.
Thanks again -Tony-
Maytag model 41 washer. Beautiful original Turbo Antique Washing Machines 2 01-19-2017 08:51:12 PM
AB magneto kill switch dlp Magnetos, Ignition Coils and Spark Plugs 1 10-05-2015 11:18:40 AM
Maytag 72d kill switch? Whozawhat Maytag Engines and Collectibles 6 02-20-2013 12:54:03 PM
Kill Switch Jim Alexander Hit & Miss Gas Engine Discussion 2 11-10-2012 08:18:22 PM
Wisconsin TFD - Kill Switch bondoo0 Wisconsin Engines 9 03-28-2011 06:41:43 AM
