Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Prototype Engine
this thread has 3 replies and has been viewed 1415 times
Old 11-23-2018, 05:18:10 PM
Group44XJS Group44XJS is offline
Default Maytag Prototype Engine
I bought the prototype Maytag engine from Rusty Steel a couple of months ago, and I finally have it running. If you'd like to see it in action, just visit the link below to see my youtube video.
https://www.youtube.com/watch?v=Rif4YA7lzRs
Old 11-25-2018, 03:40:13 PM
Default Re: Maytag Prototype Engine
Here are some pictures of the engine as I unpacked it and as I cleaned and built it. This is for those who wanted to see what was inside.
https://drive.google.com/drive/folde...YC?usp=sharing
The Following 3 Users Say Thank You to Group44XJS For This Post:
Old 12-18-2018, 06:25:15 PM
I am surprised that the exhaust is on top of the carb. Are the cylinders able to be mounted on the block reversed, or are the transfer passages machined into the block? I would think that you would not want to heat the carb with the muffler so close by.
Old 12-18-2018, 10:14:43 PM
If you looked at my photos on my Google drive folder you will see that I guess you could turn the jugs around but than you have the carb close it the spark plugs.If you look real close at the photos of the base you can see the grain of the wood and the nails that held the pattern together.I did not paint any of the alloy parts I just cleaned every thing very good and I used that alloy polish that some guy sells on Ebay for Maytag flywheels.As I said in the video I would not use the engine to run something because the back cylinder runs a lot hotter than the cylinder that is close to the flywheel.Who ever made the crankcase casting did a very nice job but the castings weep fuel all over the place.And if you look closely the machine work it was top notch.I also forgot to say that the mag coils and points were Maytag model 82.
Tracked Rumely Prototype David Hoover Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 16 11-25-2017 09:27:46 PM
Getting a steel prototype made? hypoxide Machine Shop and Tool Talk 3 07-10-2014 08:28:05 PM
Robertsonville Engine - The Prototype. Denis Rouleau Hit & Miss Gas Engine Discussion 10 10-11-2009 09:28:07 PM
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Hit & Miss Gas Engine Discussion 16 11-19-2008 12:45:49 AM
12-25 Case Prototype? JT Buice Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 12-21-2006 02:16:06 PM
