Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
Repaired-recreated my Bennett bottom mount trim tabs
this thread has 2 replies and has been viewed 553 times
Old 01-10-2019, 05:19:06 PM
Default Repaired-recreated my Bennett bottom mount trim tabs
These go on my old boat.
I have been planning for a long time to do this. The original 50 yr old tabs were badly rotten.
I bought a piece of 316 SS of 2x4 feet to to make larger tabs of 42 by 12. Originals were 42 x 9" type 304 ss.
The hardest part was cutting the SS sheet metal. Separated the big piece with a shear and bent the hook edge on a brake. The wing edge drop fins had to be bent at an angle as the transom is curved. Cut the old tab upright edge off to form the new backbone of the tab using my jigsaw and specialty SS blades. Regular metal cutting blades failed. That SS sheet metal is very hard to cut. I then coated the tab with Por15 silver. I simply sanded the sheet metal, but maybe next time will use their metal etcher, phosphoric acid. It is supposed to make them waterproof, so should help deal with corrosion. Por15 is just like paint except it becomes a very hard plastic surface. I looked at Rust Bullet and MasterSeries coatings, but the POR15 was cheaper and for this purpose is fine.
I used SS 3/16 rivets to join the back to the plane. I heated the rivets red hot while in position and slammed them down with a 4 lb sledge. A piece of old iron for the otherside of the rivet gave it the support to do that.
Then I re-coated another coat of Por15.
ID:	326085   Click image for larger version
ID:	326086   Click image for larger version
ID:	326087   Click image for larger version
Old 01-10-2019, 05:20:09 PM
Default Re: Repaired-recreated my Bennett bottom mount trim tabs
Second set
ID:	326089   Click image for larger version
ID:	326090   Click image for larger version
ID:	326091   Click image for larger version
Old 01-10-2019, 05:21:12 PM
Last one , shows the underside.
The Following User Says Thank You to sdowney717 For This Post:
Bill Bennett BillyBoyEngines Plntdctr Hit & Miss Gas Engine Discussion 0 01-17-2018 05:28:46 PM
Bennett Carburator Paul Johnson Carburetors, Mixers, Fuel Pumps and fuel delivery 1 10-18-2017 09:37:36 PM
What tractor uses this Bennett air cleaner? flyguy5219 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 06-20-2014 11:25:28 PM
Antique style japan black recreated: a demonstration Reid Paint Shop 11 03-08-2013 12:41:42 PM
Bennett carburetor I.D. TSeaberg Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 01-13-2011 02:51:33 PM
