Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
newbie again maytag 92
this thread has 6 replies and has been viewed 695 times
Old 01-24-2019, 06:35:43 PM
gmgibbs1 gmgibbs1 is offline
Default newbie again maytag 92
I couldn't find the serial #on cooling fin but a partial on the flywheel(02973),also on the caution tag model 92m ,231 long frame and a square condenser.Can anyone give a rough idea what year this motor is.The inspection cover is missing also and would like to know which one belongs on it.Thanks........George
Old 01-26-2019, 01:58:27 PM
Tony Glaser Tony Glaser is offline
Default Re: newbie again maytag 92
George, you can find what year it is by the number on the rim of the flywheel. You must have misread or mistyped the serial number as it wouldn't start with a zero.
The Following User Says Thank You to Tony Glaser For This Post:
Old 01-26-2019, 05:42:04 PM
Exclamation Re: newbie again maytag 92
The number is stamped into the exterior of the rim ABOVE a cooling fin. Not on the fin itself. If they tried stamping the number on an open area, the rim would collapse!. The serial number will have 6 digits. Without the full 6 digits, unless you have the first 3, it will be hard to date at all. The 92 type was made from 1927 to 1937, with a few more assembled from parts until around 1963, when maytag got rid of all their engine parts.
Old 01-27-2019, 04:23:49 PM
Thanks guys,first chance I get I'll double check for a stamping above the fins.Something was rubbing on the flywheel and scrubbed off the first two numbers.Do they normally put the numbers on both the block and flywheel? George
Old 01-29-2019, 08:35:58 PM
The only serial number is on the flywheel. Sadly if you can't read the number on the flywheel there isn't another way to date tour engine.
Old 01-29-2019, 11:38:44 PM
Thanks Tony.
Old 01-30-2019, 01:55:29 PM
Casting numbers off the kickstart pedal and fuel tank may get you within a year or so
Maytag Newbie Oldbug57 Maytag Engines and Collectibles 2 08-31-2017 01:30:14 PM
Maytag 92 newbie needs help TheUniversalDave1 Maytag Engines and Collectibles 9 03-15-2016 10:39:43 PM
Newbie with a maytag 92 question. greesball Unidentified Engines 2 08-03-2011 09:44:28 PM
Maytag Newbie tvandy2 Maytag Engines and Collectibles 6 05-17-2010 11:59:35 AM
Newbie w/Maytag 92 Peter Riddell Antique Engine Archives 1 12-24-2000 01:52:38 PM
