Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Model 92
this thread has 5 replies and has been viewed 699 times
Old 01-25-2019, 12:06:26 PM
LWT LWT is offline
Question Maytag Model 92
lwt, just new to maytags and my problem is my open and close jet is broke off flush with the carburetor. anyone know how to get the jet out.
Old 01-25-2019, 02:25:05 PM
Default Re: maytag model 92
Tough job. Was it hit and the shaft snapped off or was it frozen and wrung off? If it was hit, you might get it out with a reverse twist drill, just about the same size as the shaft. Only go in about 1/4", If the drill does not back it out, then an easy out should. If the shaft was seized or the easy out/drill process does not work, then I guess you will need to replace the carb, unfortunately.
Old 01-25-2019, 07:13:58 PM
LWT LWT is offline
Thumbs up Re: maytag model 92
thank you Andrew, looks like I will have to replace the mixer body
Old 01-25-2019, 08:41:31 PM
LWT LWT is offline
Unhappy Re: maytag model 92
Thanks again Andrew, now I know why I paid 75 bucks for my maytag, cant afford 75 bucks more for another mixer body. engine in good shape and fireing good , just broke off jet and a little messed up where I tried to drill it out.
Old 01-30-2019, 02:11:17 PM
Default Re: Maytag Model 92
Shop around. ou might find one on evlbay or at one of our sponsors cheaper than $75 Maybe somebody with a blown engine can help you out!
Old 01-30-2019, 02:47:36 PM
Ret AF Ret AF is offline
If you want to sell it, let me know and get your money back. I'm heading over past your way next month.
New Hit and Miss Owner JD Model E Maytag Model 92 Heelerman Smokstak Forums Meet and Greet 2 10-08-2014 02:24:28 PM
Maytag Model 92 Oiler Ball Oil/Etc. (New Model 92 Owner Questions) KubotaDiesel Maytag Engines and Collectibles 7 11-17-2013 04:35:25 PM
Maytag model 92 Jerry B Small Air Cooled Gasoline Engines 3 03-15-2013 09:18:52 PM
Maytag model 19 jmsolomonson Maytag Engines and Collectibles 2 10-12-2010 06:55:55 PM
Maytag Model 82 Junkologist Maytag Engines and Collectibles 9 01-29-2008 10:01:31 PM
