Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Help - model 92 stuck flywheel
this thread has 2 replies and has been viewed 537 times
Old 02-02-2019, 08:45:39 PM
jbshocks jbshocks is offline
Default Help - model 92 stuck flywheel
So I know the typical ways of removing flywheel. I tried laying half on the bench and tap it with a hammer. This worked on my other 4 this weekend. This one no amount of tap did the job. I was using about a 2 pound brass hammer. When it still would not go I got a bigger steel hammer and gave it a big hit after heating the hub with map gas. Unfortunately the nut split in half and I hit the end of the crank. I can probably clean it up with a thread file. Any tips on getting this thing off. I really don't want to hurt the flywheel as it is a first year serial number and belongs on my very first engine. I had swapped them 30 years ago to make the engine run that it is stuck on.
Will heating with acetalyne torch help? I have an extra hub, what about using a die grinder cut off wheel to split the hub?
Also anyone know the thread size of the crank shaft?
Old 02-02-2019, 08:55:28 PM
Default Re: Help - model 92 stuck flywheel
5/8" - 18 thread size. Just keep playing with it. Try to find what's called a "Hi Nut" Used on automotive rear end "U" bolts. It's somewhat longer than a regular nut and you can screw it down close to tight, on the crank and hammer away on it.
Old 02-03-2019, 06:20:42 PM
Well I sort of had to admit defeat. I painstakingly repaired the threads with tiny file, thread file and a die. Obtained a deep grade 5 nut. It started to screw up the threads again and I needed a usable crank more than the hub. Plus I didn't want to risk the flywheel. I used a dremel with a cut off wheel and split the hub right on top of the key way. Now the flywheel is back on the original engine where it belongs.
IHC LB stuck flywheel FarmallPaul Hit & Miss Gas Engine Discussion 17 01-26-2015 02:06:02 AM
Maytag Model 92 Horribly stuck flywheel Russell M Maytag Engines and Collectibles 11 12-18-2014 04:49:02 PM
Maytag 92 Flywheel stuck Bigjoedo Maytag Engines and Collectibles 4 05-05-2011 06:19:05 PM
Flywheel bolt stuck & then some E. Barr Onan Generators 8 11-02-2009 07:24:49 PM
Stuck flywheel Dewayne Isaacs Garden Tractors and Mowers 8 06-27-2008 09:01:05 PM
