Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 92 using a Lunkenheimer #0 Drip Oiler
this thread has 3 replies and has been viewed 569 times
Old 02-17-2019, 05:21:21 PM
Captmark Captmark is offline
Default Maytag 92 using a Lunkenheimer #0 Drip Oiler
OK guys I am very new to this and have far more questions than answers. I will limit this post to just one of them, so here goes. I have a Lunkenheimer #0 drip oiler and was wondering if it would work instead of the ball drip oiler that is on my 1936 Model 92? Could this work for the crankshaft lubrication required for the 92? Any info will be gratefully appreciated!
Thanks,
Mark
Old 02-17-2019, 06:09:01 PM
Default Re: Maytag 92 using a Lunkenheimer #0 Drip Oiler
Well, I doubt the oiler has the correct thread for the 92, The main bearing oiler's purpose is to provide ample lubrication to the bearing prior to the engine starting. After the engine starts, it's self lubricating.
Old 02-18-2019, 12:13:46 PM
Turbo's Avatar
Turbo Turbo is offline
It would work, but it is not needed. The threads in the block are 1/4-20 so you would have to make some sort of adaptor. The early engine did not even have an oiler and the ones I have without it are hardly worn anyway.
Old 02-19-2019, 03:05:23 PM
Exclamation Re: Maytag 92 using a Lunkenheimer #0 Drip Oiler
The purpose of the ball oiler was to provide added lubrication to that bearing for start up. As noted, early engines did not use it. In actuality, your oiler probably would not stand up to the vibration either. If it is not a sealed type oiler, iy won't work, as engine crankcase pressure will blow the oil out of it before the oil could reach the bearing! There are no seals on the bearings, they depend on oil weeping out during crankcase compression during the power stroke, for lubrication. That is why you need OIL to lubricate the maytags. Modern lubes are too thin and leave no residue to provide a seal or lubricate the bearings. 16:1 SAE 30 Non Detergent or TCW-3 OIL only! For that ball oiler - only a drop or 2 is needed
Drip oiler I.D. Tanner Remillard Hit & Miss Gas Engine Discussion 2 07-08-2018 09:25:41 PM
Lunkenheimer Ball oiler, Gas Engine Drip no less Randy Hart Hit & Miss Gas Engine Discussion 3 03-17-2013 10:03:58 AM
Lunkenheimer drip oilers Ray Cardoza Hit & Miss Gas Engine Discussion 2 10-26-2008 01:55:44 AM
New oiler for me - Detroit Lubricator drip oiler Ray Cardoza Hit & Miss Gas Engine Discussion 0 07-03-2008 08:44:43 PM
Drip oiler Dale S Hit & Miss Gas Engine Discussion 2 07-21-2005 11:05:36 AM
