Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
A Little More Cheap Induction Heating Power
this thread has 9 replies and has been viewed 1239 times
Old 02-23-2019, 12:02:14 AM
Default A Little More Cheap Induction Heating Power
I am in the process of upgrading my 1800 Watt ZVS Induction Heating system to 2500 watts. Still not an "industrial" machine, but it has a number of practical uses in my home shop. In this video, I discuss my plans to make the change:
https://youtu.be/xdTUZZB6UaI
Pete Stanaitis
The Following 4 Users Say Thank You to Pete Spaco For This Post:
Old 02-23-2019, 07:05:59 AM
Default Re: A little more cheap Induction Heating Power
Man you're having fun designing this induction equipment. I wish I had contacts at the induction company I worked for. I'd get you a tour and you could chat with the designers and likely let you run some 10 to 500kW equipment.
Old 02-23-2019, 12:06:07 PM
I worked for IpsenLab and Ipsen Industries in Rockford Illinois back in the 1960's. At IpsenLab, I managed the recently formed vacuum heat treating department. In the bay next to it was the induction heating department, which had one 25KW unit at the time. So I did have a chance to see it in action. It was a one man operation and that guy was an artist at coil design, as far as I am concerned.
Back then, the companies that built commercial radio station transmitters often sold induction heating equipment, too. Almost the same machines, just a bit lower in frequency.
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 02-23-2019, 07:53:00 PM
Dennis Peters Dennis Peters is offline
I currently work for a heat treating company and use 3 different size induction machines for heat treating and induction brazing work. We have a large selection of coils but i still have to make a custom coil from time to time. We have a lot of vacuum furnaces, a few are Ipsens . I do a lot of vacuum brazing work. Interesting work.
The Following User Says Thank You to Dennis Peters For This Post:
Old 03-06-2019, 09:31:52 PM
My 2500 Watt Induction Heater is now up and running.
The video of the "improved" setup and a bit about operation is here:
https://youtu.be/YIa98jXLQ9U
Pete Stanaitis
The Following 2 Users Say Thank You to Pete Spaco For This Post:
Old 03-31-2019, 09:55:55 PM
More upgrades to the 2500 watt ZVS induction heater. I think I now have a heating machine that can just be plugged in and used as needed.
This will be my last post about this device, for a while, at least.
Pete Stanaitis
Old 05-22-2019, 05:47:29 PM
Lotsa water over the dam.
Continuing to work with both the 2500 watt induction heaters and the 1000 watt unit. melting copper, adding frequency meters and annealing some more cartridges as I mess around with different coils.
Not too sure how many of you are interested, but I don't see a lot of activity here lately, so I hope you don't mind.
See:
http://spaco.org/Blacksmithing/ZVSIn...eaterNotes.htm
and:
and:
http://spaco.org/Blacksmithing/ZVSIn...tionHeater.htm
Pete Stanaitis
Old 08-04-2019, 12:53:00 PM
Default Re: A Little More Cheap Induction Heating Power
More work coil testing.
This time a large pancake coil:
https://youtu.be/iLBSsJn7z-I
Pete Stanaitis
Old 08-08-2019, 11:11:34 PM
msellers msellers is offline
Very cool, have always been intrigued by these systems. They have so many applications and definitely remind me of some scifi stuff from the old movies.
Mike
Old 09-16-2019, 10:52:30 AM
Another small scale induction heating video.
This time I summarize the work coil making process that I use:
https://youtu.be/rlJxUrhotaA
Pete Stanaitis
Annealing Brass Cartridge Casings/ Induction Heating Pete Spaco Blacksmithing and Metallurgy 10 05-11-2019 10:58:30 AM
heating/power co-generation len k Onan Generators 34 04-09-2019 04:10:16 AM
Cheap induction forging, Maybe? Pete Spaco Blacksmithing and Metallurgy 15 01-03-2019 01:00:18 AM
Induction heating to free piston Plunger Hit & Miss Gas Engine Discussion 2 10-23-2010 09:14:25 PM
electrolysis power supply on the cheap KeithW Hit & Miss Gas Engine Discussion 7 04-04-2006 12:39:57 AM
