Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Finding G-carb parts
this thread has 9 replies and has been viewed 558 times
Old 03-28-2019, 01:33:03 PM
joder joder is offline
Default Finding G-carb parts
I've got a main bearing that has been purported to be for a G-carb upright engine. I was going to just block-off the intake port and use it with the upright parts I was going to Frankenstein-together into a running E-carb engine and got to thinking - are there any loose G-carbs & tank-tops/crankcases out there? Would I be looking at fruit-jar-like money to finish a G-carb engine off? Is anybody repopping the G-carbs and parts?
Just thinking out loud. Thanks for any input.
Old 03-28-2019, 11:18:31 PM
ulgydog56's Avatar
Default Re: Finding G-carb parts
well did you try evilbay……..
Old 03-28-2019, 11:44:42 PM
Still new to Maytags so I may be wrong on what I have.
Old 03-29-2019, 08:59:48 AM
If the parts WERE on eBay, I must have missed them; if they're GOING to be listed on eBay - give me a heads up if/when it'll happen if you're going to be listing some.
Thanks.
Old 03-29-2019, 09:45:48 AM
Clement Rook Jr. Clement Rook Jr. is offline
jyoder,the G carb crankshaft bearing is # S41,but the # is not cast into the part.a picture of what you have will help us identify it for you.
Old 03-29-2019, 10:00:30 AM
Hopefully they attach - they may be too big.
Pictures #4 & #5 are the bearing in question (bare metal) next to an e-carb bearing (red) - just a little bit different
ID:	331614   Click image for larger version
ID:	331615   Click image for larger version
ID:	331616   Click image for larger version
ID:	331618   Click image for larger version
Old 03-29-2019, 09:05:10 PM
joder,neither of the main bearings shown fit a G CARB maytag. they may have been used on a D carb, they appear to be variations of the same part.
The Following User Says Thank You to Clement Rook Jr. For This Post:
Old 03-31-2019, 11:02:45 AM
Turbo's Avatar
Turbo Turbo is offline
I agree, I think what you have there is a D carb bearing flange. The inside face is machined flat to use the rotary check valve setup compared to the E carb flange which is machined off on the side. The E carb has a small poppet valve that acts as the air check valve.
The Following User Says Thank You to Turbo For This Post:
Old 03-31-2019, 11:35:06 AM
Thank you all for your help - I guess I need to find out the likelihood of finding d-carb parts, then.
Old 03-31-2019, 10:42:00 PM
Nathan K. Nathan K. is offline
Hi Joder,
If your looking for parts send me your email-I might have some.
Good luck Nathan.
Clinton Engines 3.5hp Help Finding a Replacement Carb Travisneer Small Air Cooled Gasoline Engines 4 04-15-2018 06:37:09 PM
Help finding parts for Onan 4.0 CCK c east Onan Generators 6 04-11-2011 12:59:10 PM
need help finding Onan parts GHanners Onan Generators 4 09-18-2009 02:09:26 AM
Need help finding parts 7cm21rv wsax Kohler Generators 8 07-17-2008 02:48:26 AM
Help finding parts and manual Bohunk Hit & Miss Gas Engine Discussion 0 06-19-2006 07:37:19 AM
