Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Model 31 Help
this thread has 7 replies and has been viewed 720 times
Old 05-02-2019, 05:01:12 PM
Bolens Bolens is offline
Default Maytag Model 31 Help
Hi, I’m new to these engines. I took two in trade as they looked interesting. One was restored and runs. The other had no spark. I removed the flywheel and cleaned the magnets and points. The gap was way off so I set it to .020. I got spark and got it running. It’s missing some parts and I’m wondering where I may find them. I saw a few on eBay.
I need a spark plug as the electrode looks too short and it won’t spark. Ebay has some for $75 but I only need the center piece with the insulator and electrode.
Also need the flat piece that goes on the kick starter. It is attached with two shoulder bolts I think it’s some sort of stop.
Need an air filter,muffler and flange, grounding tab and a flywheel pulley.
I used transmission fluid on that engine and it looks pretty nice. Thank you for any help.
ID:	333967   Click image for larger version
ID:	333968   Click image for larger version
The Following User Says Thank You to Bolens For This Post:
Old 05-02-2019, 05:59:45 PM
Default Re: Maytag model 31 help
Update: I found everything on eBay except the spark plug, still searching...
Old 05-02-2019, 11:21:12 PM
stufforbud stufforbud is offline
You can get a new 1/2" pipe sparkplug at NAPA unless you really want an early one.
The Following User Says Thank You to stufforbud For This Post:
Old 05-03-2019, 06:47:47 AM
Default Re: Maytag Model 31 Help
Thanks stufforbud I may just get one of those so that I can run it without having to swap plugs every time I run it. I was thinking of powering my cider press grinder box with it. It would look really nice. The grinder box is very small I think this engine could easily run it.
ID:	334027   Click image for larger version
Old 05-03-2019, 08:35:20 AM
Tony Glaser Tony Glaser is offline
I should have what you are looking for. Call or text me and I can send you a picture and price. 320-808-7438 thanks
The Following User Says Thank You to Tony Glaser For This Post:
Old 05-03-2019, 02:57:24 PM
Exclamation Re: Maytag Model 31 Help
There are several plugs you can use in your Maytag. As stated earlier, it is a 1/2" pipe based plug. The proper plug is either a Champion #34 - Gas Engine Special or a Champion Maytag plug, made by Champion specifically for Maytag. These are 'long reach' plugs which extent into the combustion chamber for better combustion and anti fouling purposes. The champion X plug ( model T plug)will work too, but might have a tendency to foul if you run rich with no load. All 3 plugs come in take apart versions, and some of the X are one piece. If you get the take apart, they are easier to clean if they foul. Champion also makea an A-25, both in one piece and take apart. Not sure on performance though.
Remember, the Maytag uses 16:1 (1/2 pint to a gallon of gas), using SAE30 oil or TCW-3. NO modern lubricants nor premix lubricants, as they are too thin to stay in the soft bronze bearings.
Old 05-03-2019, 04:05:46 PM
Clement Rook Jr. Clement Rook Jr. is offline
bolens, get a 3095 spark plug on ebay .about $5.00 + - not old but will run your engine just fine.
The Following User Says Thank You to Clement Rook Jr. For This Post:
Old 05-04-2019, 06:36:19 AM
Guys thank you for all your information on the plugs. I got a couple from NAPA for now. Tony I’m interested in what you have for plugs. I’ll give you a call to talk about it. One of the original Maytag plugs works fine, the other has broken porcelain and doesn’t work.
New Hit and Miss Owner JD Model E Maytag Model 92 Heelerman Smokstak Forums Meet and Greet 2 10-08-2014 02:24:28 PM
Maytag Model 92 Oiler Ball Oil/Etc. (New Model 92 Owner Questions) KubotaDiesel Maytag Engines and Collectibles 7 11-17-2013 04:35:25 PM
Maytag Model 92 Rob Williams Maytag Engines and Collectibles 2 09-06-2008 12:31:51 PM
Maytag model 72 Robert Miller - Tucson Antique Engine Archives 4 10-03-2001 08:36:55 PM
Maytag Model 31 JW(NC) Antique Engine Archives 5 10-02-2001 09:08:51 AM
