1929 Briggs and Stratton Issues
this thread has 16 replies and has been viewed 975 times
Old 06-14-2019, 06:06:32 PM
acisbest acisbest is offline
Default 1929 Briggs and Stratton Issues
Hello,
I just picked up a 1929 Briggs and Stratton at a flea market. I probably paid too much... He said it was frozen from sitting.
Got it home and took off the head, everything looked great. Opened up the shroud and found that the flywheel was touching the shroud sheet metal. After I took the flywheel off the engine spun freely with great compression.
So, now I need to know why this flywheel is hitting. My guess is that it is the wrong flywheel. I'll try to post pictures.
Where can I get parts for this old engine?
Regards,
acisbest
The Following User Says Thank You to acisbest For This Post:
Old 06-14-2019, 08:40:39 PM
radiodoc radiodoc is offline
Default Re: 1929 Briggs and Stratton issues
A model and type number would help.
Old 06-14-2019, 10:53:41 PM
ulgydog56's Avatar
here, here.....
Old 06-16-2019, 11:35:29 AM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
The flywheels on those early Briggs engines are poor quality pot metal and tend to warp badly. Usually they begin to drag on the armatures as well and require an hour or two to true up where they will turn over and make sparks. Flywheels are pretty readily available for most models but as they say, we need more info to be able to offer you help. Most likely you have an FH, then again you mighta got lucky and picked up something a little more rare.
Old 06-16-2019, 02:17:58 PM
Mike in NC's Avatar
That early of an engine should not have a type number.
I had one that was rubbing the shield riveted to the backing plate, dirt had gotten down between the backing plate the sheet metal and pushed the sheet metal out until it was rubbing the flywheel.
SmokStak Member #28
Old 06-16-2019, 07:36:59 PM
---------- Post added at 07:35:08 PM ---------- Previous post was at 07:29:23 PM ----------
The number plate seems to be broken off of the rivets on the shroud. Then engine has an nice wooden stand on wheels with a plate that says "1929 Briggs, 18 years of service."
---------- Post added at 07:36:59 PM ---------- Previous post was at 07:35:08 PM ----------
The flywheel is toast in my opinion. Inner cracks. Where can I get a new one?
The Following 2 Users Say Thank You to acisbest For This Post:
Old 06-16-2019, 07:53:04 PM
Mike in NC's Avatar
That would be a model FH.
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Old 06-16-2019, 08:07:28 PM
Thanks for identifying it. Where could I find a parts diagram? Did it ever have a governor? Attaching a few more pictures.
Old 06-16-2019, 08:18:22 PM
Mike in NC's Avatar
Looks like someone adapted a Model Y carb to the engine. There should be a governor under the little stamped steel flywheel.
Look at page 6 of the manual (link below), it shows the governor.
The manual also has a parts breakdown in the back of it.
Briggs & Stratton FH Manual
SmokStak Member #28
Old 06-20-2019, 01:46:08 AM
Junkologist's Avatar
Originally Posted by acisbest View Post
[/COLOR]The flywheel is toast in my opinion. Inner cracks. Where can I get a new one?
That flywheel looks fine to me. I would run it. I can’t post a pic until next week, but I can show you what a bad one really looks like.
Mike
SmokStak member #146
The Following 2 Users Say Thank You to Junkologist For This Post:
Old 06-20-2019, 05:20:10 AM
Tim B's Avatar
Tim B Tim B is offline
Turn your crankshaft to different positions and check for up and down play also. That too could give erratic/no spark and rubbing.
Old 06-28-2019, 09:01:42 AM
The flywheel is probably warped. Does anyone know what the taper angle is on the crankshaft? I think I'm close with 10 degrees. I'm trying to make a mandrel for the flywheel and then true it up on the lathe if I can.
My guess now is that the flywheel brass has gotten out of round and that's why the flywheel is hitting the back plate.
Old 06-28-2019, 09:20:34 AM
mcolopy mcolopy is offline
This might help give you a idea of what should be there
The Following User Says Thank You to mcolopy For This Post:
Old 06-28-2019, 11:20:09 AM
Default Re: 1929 Briggs and Stratton Issues
Thanks, that's a nice engine. Mine is cobbled together. It's missing most of the governor pieces. I'll keep an eye out on ebay or at vintage swap meets.
Will this engine get hurt by over revving without the governor? Will the intake valve eventually limit the high speed?
Old 06-28-2019, 05:53:54 PM
Tony Glaser Tony Glaser is offline
If you need the wooden governor collar I made a few this winter. Send me a message if you need one. Also there is a guy in Michigan I think that sells parts and there cheaper than eBay. Google antique Briggs engine parts, I think you will find him.
The Following User Says Thank You to Tony Glaser For This Post:
Old 06-30-2019, 12:20:11 AM
Motormowers's Avatar
The flywheel and mag plate are prob warped, very common on this era Briggs. The main bearing might also be badly worn.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 06-30-2019, 12:14:19 PM
Here’s some pics of a truly bad flywheel.
ID:	338227   Click image for larger version
ID:	338228   Click image for larger version
ID:	338229   Click image for larger version
Mike
1929 Briggs & Stratton FI straight fin paul midgley Small Air Cooled Gasoline Engines 5 03-24-2017 09:23:19 AM
1929 Briggs and Stratton model FH straight fin hampton8098 Small Air Cooled Gasoline Engines 4 07-09-2015 09:48:26 AM
1929 Briggs abd Stratton and 1935 John Deere chade1968 Hit & Miss Gas Engine Discussion 0 11-25-2011 12:37:31 PM
1929 Briggs & Stratton FH technical questions chade1968 Small Air Cooled Gasoline Engines 2 10-26-2011 01:24:07 PM
1929 Briggs & Stratton FH piston wanted chade1968 Small Air Cooled Gasoline Engines 2 10-25-2011 03:19:18 PM
