Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Home built Maytag generator
this thread has 6 replies and has been viewed 677 times
Old 07-29-2019, 11:34:16 AM
Turbo's Avatar
Turbo Turbo is offline
Default Home built Maytag generator
I just picked up this homemade gen setup using a model 72 engine. Either someone bought the LeClair parts and put this together or this engine powered something else and was adapted to this generator. The pulley is cast iron 4.5 dia. and part#SC107. The engine S/N is 116582X built in June 1947. The base looks very much like a Simmer pump base but judging by the crummy welds and no pump platform I think it is home built. It also has an air cleaner which makes me think this could have been a lawn mower engine at one time. Any more info is appreciated. thanks
ID:	340264   Click image for larger version
ID:	340265   Click image for larger version
ID:	340266   Click image for larger version
The Following 5 Users Say Thank You to Turbo For This Post:
Old 07-29-2019, 01:41:50 PM
Kevin Weis Kevin Weis is offline
Default Re: Home built Maytag generator
Yea, I think it was fabricated back in the 50's. I agree probably was made for a lawnmower originally.
The Following User Says Thank You to Kevin Weis For This Post:
Old 07-29-2019, 06:12:47 PM
bobeg bobeg is offline
100% right home made
The Following User Says Thank You to bobeg For This Post:
Old 07-29-2019, 09:57:01 PM
Tony Glaser Tony Glaser is offline
Turbo I think you are absolutely right home made from a lawn mower engine.... and after you give the guy his dues for the lead on this engine I’m certain you gave to much for it. all kidding aside I like it a lot and it should be displayed as is or close to it. It’s really amazing what lengths people went to for a “tool” they needed. For what’s its worth my opinion is keep it this way and display it as you acquired it.
The Following User Says Thank You to Tony Glaser For This Post:
Old 08-05-2019, 02:58:25 PM
Does the generator have a information tag on it ? Anything would be helpful.
The Following User Says Thank You to EvilDr235 For This Post:
Old 08-05-2019, 03:08:14 PM
I like oldstuff I like oldstuff is online now
It looks like a Bodine DC motor that is spun to produce x DC volts.
Old 08-23-2019, 11:50:39 AM
Turbo's Avatar
It is a General electric DC motor that is spun to make it generate current. There is no other info on the motor besides the MFG. I am assuming 110V DC Not sure is GE produced 32 volt stuff? I decided to disassemble it and make a simmer pump. The base is homemade but looks almost identical to Simmer pump base. I have a nice late Wico twin setup for a Simmer pump but is missing the base. Then plan to find a lawn mower and build a LeClaire lawn mower kit setup with this engine. Thanks for the info guys!
Home built bike JohnAW Antique Motorcycles 9 12-08-2014 10:54:13 PM
Home built hot air engine Bruce Sutton Hot Air Engines 0 07-31-2012 03:11:36 PM
Home built generator dasratsel Generators & Electric Motors General Discussion 3 12-27-2011 03:36:51 PM
Home built H&M or converted B&S to H&M, anyone done it? Mac Leod Hit & Miss Gas Engine Discussion 30 10-14-2008 08:18:54 PM
Home built tractor value? Andy Williams Antique Farm Tractors 6 05-01-2008 01:33:37 AM
