Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag Model 82 - New Owner
this thread has 4 replies and has been viewed 323 times
Old 08-14-2019, 02:30:06 PM
Saba II Saba II is offline
Default Maytag Model 82 - New Owner
Hey there everyone. Just picked up a gem of a model 82 and it is my first Maytag engine and really my first antique engine. I have been doing a lot of reading on these the past 48hrs and I think I got a good deal on it at $80. Anyhow, before I put fuel in and try to run this old girl I want to be sure it is ready to be run and I wont wreck anything by trying to fire it. What's obvious to me is that I'll need to go through the ignition system and clean that up. I should probably inspect the carb and clean that out. Other than that am I missing anything? I did find a manual online so I can check my points and it looks like they should be gapped to .020". Thanks for the help.
ID:	341426   Click image for larger version
ID:	341427   Click image for larger version
The Following 2 Users Say Thank You to Saba II For This Post:
Old 08-14-2019, 03:01:28 PM
Default Re: Maytag Model 82 - New Owner
Points .020. Plug .025. Ggas - 16:1 SAE 30 or TCW-3 OIL ONLY - no synthetics, one mix or different ratios. DO NOT remove the coil or you will need to send it out to be recalibrated! The ignition system is similar to the 92, but there are differences.
Old 08-14-2019, 03:20:04 PM
Good to know. All I have done is pull the plug and check spark but as one can imagine, I didn't have any. So I am going to give it all a good cleaning and see what happens next.
The Following User Says Thank You to Saba II For This Post:
Old 08-14-2019, 05:23:58 PM
The Maytag Collectors Club has alot of info on the Maytag engines and Maytag company history
www.maytagclub.com
Welcome to the Stak
Old 08-14-2019, 10:52:54 PM
Tom G Tom G is offline
That engine would be a bargain at THREE times what you paid for it!
New Maytag 92 Owner Needs Help ronv Maytag Engines and Collectibles 2 10-23-2016 06:38:32 PM
New Hit and Miss Owner JD Model E Maytag Model 92 Heelerman Smokstak Forums Meet and Greet 2 10-08-2014 02:24:28 PM
Model 92 Maytag first time owner Rhuff Maytag Engines and Collectibles 15 05-23-2014 11:08:21 AM
Maytag Model 92 Oiler Ball Oil/Etc. (New Model 92 Owner Questions) KubotaDiesel Maytag Engines and Collectibles 7 11-17-2013 04:35:25 PM
guess im a maytag owner now Elwood Maytag Engines and Collectibles 5 01-09-2012 01:27:45 PM
