Ideal Model V Info/Help
this thread has 12 replies and has been viewed 638 times
Old 08-20-2019, 09:42:39 PM
Colin583 Colin583 is offline
Default Ideal Model V Info/Help
Hi Everyone,
I am brand new to this forum so forgive me if I do something wrong
I recently got this strange (and maybe rare) Ideal Model V engine. I was just curious if anyone a had any information about it. If anyone knows what the carb is or what it's from, the year these things were made, how many were made, or any information it would be a appreciated!
Here is a video I made of it:
https://www.youtube.com/watch?v=55O7D03o5xg
Thanks,
Colin
ID:	341915   Click image for larger version
ID:	341916   Click image for larger version
ID:	341917   Click image for larger version
The Following 4 Users Say Thank You to Colin583 For This Post:
Old 08-20-2019, 11:48:58 PM
ulgydog56's Avatar
Default Re: Ideal Model V Info/Help
very cool motor......
Old 08-21-2019, 01:07:12 AM
Ron Davis's Avatar
Ron Davis Ron Davis is offline
I will post a picture of mine i have two of the engines one is a nice complete original engine , they do jump around when they are not on the mower, the mowers where very heavy..
Old 08-21-2019, 02:43:14 AM
I have always liked old engines. They are so easy to work on and adapt parts from other engines to keep them running unlike modern engines. I imagine years ago someone needed to keep this engine working and used what they had. If it were mine I would probably leave it as found and correct the minor problems it has. I wonder if they have a category for engines of this type ? If they don't, they should.
---------- Post added at 02:41:46 AM ---------- Previous post was at 02:36:50 AM ----------
I meant to say, I wonder if at engine shows do they a category for farmer /poor man home repaired engines ?
---------- Post added at 02:43:14 AM ---------- Previous post was at 02:41:46 AM ----------
Welcome to the forum.
Old 08-21-2019, 11:32:53 AM
Ron Davis's Avatar
At first i though the mixer was a early Jacobson mixer witch is a engine of similar size , but now i look closer its a early aftermarket carburetor for a model T ford , that carburetor is probably more harder to find than the engine...
The Following User Says Thank You to Ron Davis For This Post:
Old 08-21-2019, 03:47:54 PM
Ron Davis's Avatar
Here are some pics of mine ... thay made two sizes
ID:	341969   Click image for larger version
ID:	341970   Click image for larger version
ID:	341971   Click image for larger version
The Following 3 Users Say Thank You to Ron Davis For This Post:
Old 08-21-2019, 09:24:02 PM
Tim B's Avatar
Tim B Tim B is offline
Sounds pretty good there. Here is my Ideal on the mower. I took this video a few years back when I first got it. It needs some tlc and a throttle control. Good luck.
The Following 4 Users Say Thank You to Tim B For This Post:
Old 08-21-2019, 09:51:01 PM
Thanks!
---------- Post added at 09:51:01 PM ---------- Previous post was at 09:45:44 PM ----------
Thanks for all the info so far! I didn't expect this much response!
EvilDr235- I totally agree! They tell such awesome stories!
Ron Davis- You are right! I would never have thought it to be a model T carb. After some research, I think it's a D&B Harrington carburetor! Thanks so much! Those are some nice pieces BTW I didn't know they made 2 sizes. Is that the original carb on yours?
Tim B- Nice video! One of the first ones I found after I looked this thing up!
The Following User Says Thank You to Colin583 For This Post:
Old 08-22-2019, 07:50:23 AM
JWitt's Avatar
JWitt JWitt is offline
Mine seems to be kind of an odd-ball. Both valves are side valve.
ID:	342013   Click image for larger version
ID:	342014   Click image for larger version
When in doubt, smoke em' out
The Following 3 Users Say Thank You to JWitt For This Post:
Old 08-22-2019, 08:29:04 AM
HBurk HBurk is offline
One thing you gotta give ole Tim, his junk usually runs and does what it's supposed to!
The Following 2 Users Say Thank You to HBurk For This Post:
Old 08-23-2019, 11:41:15 AM
Couple of questions:
-Does anyone know:
-How rare these thing are or how many were made?
-What are the numbers that are stamped into various pieces of the engine?
- HP rating?
-Year of production?
Thanks!
-Colin
Old 08-31-2019, 08:53:31 AM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
These engines were supplied with Tillotson carburetors as follows
MS-10A carbs from 1927 through 1928.
MS-10B carbs from 1929 into 1930.
MS-10C carbs from 1930 through 1933.
Seems there was some overlap in the year 1930. I have no idea how many were produced but they are not really rare. Scarce, when compared to say a Briggs FH, but not totally rare. Very neat, and heavy, early engines. They are completely out of balance and jump around like crazy when not bolted down to something in the 200# range. When I first started mine it was on a base consisting of a couple pieces of 2 x 4. I grabbed it to keep there from being damage when it fell over and durn near electrocuted myself with the plug wire. Thrilling!
The Following 3 Users Say Thank You to Everett Hayden For This Post:
Old 09-01-2019, 03:04:32 PM
Junkologist's Avatar
I have one like that too. Definitely don’t see many like it at all.
Mike
SmokStak member #146
Ideal model R Info 03rsixer Hit & Miss Gas Engine Discussion 3 07-07-2019 08:14:37 AM
IDEAL Model V info tubajock Small Air Cooled Gasoline Engines 27 07-20-2017 11:46:08 AM
Ideal Model S info wanted Robt. Hit & Miss Gas Engine Discussion 0 12-19-2005 01:52:48 AM
Info-Help-Ideal Model V Garry Antique Engine Archives 2 11-07-2004 08:02:44 PM
IDEAL info. Warren Jacky Antique Engine Archives 1 12-29-2002 01:57:30 PM
