Running Honda engine with stator wire unhooked.
this thread has 2 replies and has been viewed 249 times
Old 09-03-2019, 02:30:52 PM
Turbo's Avatar
Turbo Turbo is offline
Default Running Honda engine with stator wire unhooked.
I just bought a Quincy air compressor with a Honda GX390 engine. It has electric start and a small charging stator. Instead of a separate battery I am using a power wire from my truck battery to start it. But I do not want the charging system to function. The stator has one wire coming out going to the rectifier. Will unplugging the wire have any negative effects to the stator? I have search high and low online with no good answer. Thanks
Old 09-03-2019, 05:00:13 PM
Default Re: Running Honda engine with stator wire unhooked.
No problem disconnecting it. It'll just continue to make unused AC all day.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Old 09-03-2019, 07:08:52 PM
Turbo's Avatar
Thanks, that’s what I thought but started to second guess after reading on another forum that it can damage the stator. Really it is no different than a ordinary generator running with nothing plugged in. The biggest problem with searching online for anything is all the misinformation out there!
The Following User Says Thank You to Turbo For This Post:
Honda 6500SX Stator Plugs/Testing TAB Honda, Yamaha, Kawasaki, Isuszu Generators 1 11-13-2017 05:01:50 PM
Is a Honda ES6500 with "burnt out stator" worth anything? DougMcK Honda, Yamaha, Kawasaki, Isuszu Generators 5 01-06-2017 06:26:28 PM
Honda EU3000is running without battery RMak Honda, Yamaha, Kawasaki, Isuszu Generators 8 03-16-2016 11:57:16 PM
Onan 2 wire to 3 wire stator conversion? HonestJohn Garden Tractors and Mowers 0 11-08-2014 07:14:47 AM
Engine running when spark plug wire is pulled? Jon Rozevink Hit & Miss Gas Engine Discussion 25 06-30-2013 11:45:11 PM
