Please help identify this engine
this thread has 14 replies and has been viewed 987 times
Old 09-10-2019, 09:13:49 PM
Joe Spahr Joe Spahr is offline
Default Please help identify this engine
The flywheel is cast iron the muffler is cast iron. Half of the tag is missing.
ID:	343692   Click image for larger version
ID:	343693   Click image for larger version
ID:	343694   Click image for larger version
The Following 10 Users Say Thank You to Joe Spahr For This Post:
Old 09-10-2019, 09:30:14 PM
Default Re: Please help identify this engine.
There is a lot in the know people on this site. I am sure somebody will be able to ID it.
The Following User Says Thank You to EvilDr235 For This Post:
Old 09-10-2019, 09:31:54 PM
Pretty neat looking whatever it is. I am guessing a two stroke ? bet that bugger is heavy.
Old 09-10-2019, 09:37:18 PM
It is a 2 stroke & yes it is HEAVY!
The Following 3 Users Say Thank You to Joe Spahr For This Post:
Old 09-11-2019, 08:55:57 AM
Clayton Clayton is offline
That is a neat looking sucker. I have no clue but I’m sure someone knows. Unusual
The Following User Says Thank You to Clayton For This Post:
Old 09-11-2019, 10:52:35 AM
Antiquebriggsguy Antiquebriggsguy is offline
I'm thinking Johnson or Jacobsen.
The Following User Says Thank You to Antiquebriggsguy For This Post:
Old 09-11-2019, 10:59:08 AM
casertractor casertractor is online now
Johnson Utilimotor?
Old 09-11-2019, 03:31:37 PM
my vote is for cushman or jacobsen
The Following User Says Thank You to Ed Radtke For This Post:
Old 09-11-2019, 03:45:12 PM
carl knissel carl knissel is offline
I have one the same as yours and it is tagged as a jacobsen
The Following 3 Users Say Thank You to carl knissel For This Post:
Old 09-11-2019, 09:55:25 PM
Thanks for the info. I will try to find out more about it now.
Old 09-11-2019, 11:59:29 PM
enginecrzy enginecrzy is offline
Photo Re: Please help identify this engine.
found one on fleabay
https://www.ebay.com/itm/113867127796
https://www.pinterest.com/engiginecrzy/jacobsen-engine/
The Following User Says Thank You to enginecrzy For This Post:
Old 09-12-2019, 02:20:07 PM
termat termat is offline
Jacobsen. Model m1,2,3,or4. Ones I have seen with throttle
governed carbs are usually from mowers. No throttle on carb was from a gen set or pump. Yours looks like it has an aluminum rope cup. Saw one like that on a belt drive generator once.You are lucky you have the air cleaner because they are usually missing.
The Following User Says Thank You to termat For This Post:
Old 09-12-2019, 10:44:56 PM
The rope pulley looks to be cast, maybe bronze? It has a gold color in the casting. Any idea how old the engine could be?
Old 09-13-2019, 05:32:52 PM
My guess would be mid 1930s. If you search Johnson utilimotor/Jacobson you will find information.
Old 09-13-2019, 09:52:59 PM
I was able to find several interesting pictures & videos.
the early 4th of July engine find..help identify engine. Firewoodguy Hit & Miss Gas Engine Discussion 10 07-03-2014 06:41:37 AM
Can you identify this engine Kylerocky Unidentified Engines 5 04-05-2010 07:20:58 PM
Who can identify this engine? John Hanson Steam Stationary Engines, Traction Engines 12 01-09-2010 12:57:38 PM
Leroy Engine help! Please help me try to identify my Uncle's engine Sprintcars11 Hit & Miss Gas Engine Discussion 4 06-06-2009 11:08:59 PM
identify engine help Derek Pollard Hit & Miss Gas Engine Discussion 3 12-30-2006 08:32:04 PM
