Need help to identify Lauson Engine
this thread has 4 replies and has been viewed 266 times
Old 09-14-2019, 04:39:35 PM
shiftlessguy shiftlessguy is offline
Default Need help to identify Lauson Engine
The pics best describe motor.Wico ign,mech gov,suction carb with no markings.I know ill never find year as theres no tag.Bore is 2"x1.905.Thats the best i can do for info.
ID:	343969   Click image for larger version
ID:	343970   Click image for larger version
ID:	343971   Click image for larger version
ID:	343972   Click image for larger version
ID:	343973   Click image for larger version
Old 09-14-2019, 04:45:32 PM
Default Re: need help to ident lauson eng
More pics
ID:	343975   Click image for larger version
ID:	343976   Click image for larger version
ID:	343977   Click image for larger version
Old 09-14-2019, 04:57:20 PM
K-Tron K-Tron is offline
It looks like a Lauson model 55 to me. It was a pretty common cheap engine back in the day. I have seen them rated at 1-1/2 to 2 hp @ 3600rpm. Craig DeShong is our resident Lauson expert. If he does not chime in here, send him a private message. He has helped me out with my Lauson engines.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 09-14-2019, 05:33:18 PM
Oh yeah, I need to know valve lash ex, intake.
Old 09-15-2019, 02:50:07 AM
Default Re: Need help to identify Lauson Engine
Found a thread by Chris DeShong.According to his thread its either a 55s or 55b.It has either wrong carb or wrong flywheel shroud.Although Chris says that there was an upgrade kit that used float carb mt2b with shroud mounted gas tank.Im just gonna go with suction carb and use a briggs tank.Could use a pdf manual for some info.Dont know if ill try and mount tank like factory did .I'll have to see if I can remove round tank mount from shroud to make it look somewhat orignal.
Help Identify Lauson Engine Firewoodguy Hit & Miss Gas Engine Discussion 2 12-01-2017 02:06:58 PM
Help identify Lauson outboard jetdrive? Doublehaul Antique Marine Engines and Outboard Motors 12 06-03-2017 08:02:54 PM
LAUSON 2hp Flywheel Hit and Miss Help Identify Year? Sheeniman Hit & Miss Gas Engine Discussion 10 07-25-2016 02:30:26 PM
Lauson Engine: What do I have? oliver77 Small Air Cooled Gasoline Engines 1 04-05-2011 11:36:53 AM
Please help identify Lauson model Christian Berlin Small Air Cooled Gasoline Engines 4 06-18-2009 07:49:34 PM
