I found this in back of grandfathers shed, it hasa a massive steel muffler
this thread has 9 replies and has been viewed 718 times
Old 09-14-2019, 05:50:17 PM
Rye Kester Rye Kester is offline
Default I found this in back of grandfathers shed, it hasa a massive steel muffler
The muffler is so thick it hasn't rusted through or damaged in any way.
I posted photos of the carb so you could see what model it is...maybe? When I saw the engine head at first I thought, combined with the muffler, this must be an older scale airplane engine? but...
It was extremely well made, which most things were in the days of single cylinders, this muffler says "I will survive!!" I can put a tape measure by if need be for comparison but its at least 20-24" long.
I would appreciate any information, it would help me understand Gramps a bit more and what he was working on and what he may have experimented with!
ID:	343983   Click image for larger version
ID:	343984   Click image for larger version
ID:	343985   Click image for larger version
Old 09-14-2019, 06:01:25 PM
Default Re: I found this in back of grandfathers shed, it hasa a massive steel muffler
Looks golf cartish to me.
Old 09-14-2019, 07:04:55 PM
Vanman Vanman is offline
Yeah, that pulley looks like the clutch and driven end of a CVT, as commonly found in such small vehicles. The coil and it's bracket and the plastic on the fuel pump (or is that the carb?) makes me think this isn't as old as it looks. Still, a neat little two stroke.
Old 09-14-2019, 07:08:17 PM
I think it's an HL Tillotson carb
Old 09-14-2019, 07:11:34 PM
In the Harley days?
Old 09-14-2019, 07:21:50 PM
dkirk dkirk is offline
I think it's a Harley-Davidson golf cart engine.
The Following 2 Users Say Thank You to dkirk For This Post:
Old 09-14-2019, 07:30:15 PM
Everything I am finding is pointing towards that. I found a replacement muffler that was nearly exact and the specs were almost dead on.
I think you hit it.
Thanks!
Old 09-14-2019, 07:31:36 PM
And you are correct also. You were typing your msg as I was. Thank you!
Old 09-14-2019, 08:57:21 PM
K-Tron K-Tron is offline
Does the engine turn over? If it were mine I would use compressed air to blow all of the crud off of it, pull the sparkplug and muffler off and just let it sit in a 5 gallon pail of pblaster/diesel/kerosene for a while before working on it. These are a two stroke engine so you can access most of the condition of the engine without even pulling the cylinder head off.
Chris
The Following 2 Users Say Thank You to K-Tron For This Post:
Old 09-16-2019, 03:15:07 PM
If memory serves, these are 250cc (15 cubic inch) displacement engines. Two-stroke cycle, they run equally well in either direction. Originally equipped with a Dyna-Start starter/generator, the engine was motored opposite to normal rotation for reverse on the golf cart. This engine was also used on a scooter that Harley produced during the late 50's.
The Following User Says Thank You to dkirk For This Post:
Cooling an NH in a 8x10 Steel Shed AppleTech Onan Generators 22 06-19-2017 04:07:58 AM
Another tractor found in a collapsed shed Culy Antique Farm Tractors 19 03-22-2010 12:32:57 AM
Old generator found in my grandfathers basement Stephenichols Kohler Generators 4 06-19-2008 08:58:57 AM
Found an Alamo in a shed? JimS Hit & Miss Gas Engine Discussion 1 07-23-2007 12:27:31 AM
Found Small 9hp Case in shed 19-65Port Steam Stationary Engines, Traction Engines 13 03-20-2007 06:19:01 PM
