Briggs and Stratton "A" starting crank
this thread has 3 replies and has been viewed 308 times
Old 09-14-2019, 09:21:21 PM
pigpen60 pigpen60 is offline
Default Briggs and Stratton "A" starting crank
Anybody have a starting crank for an briggs model A they could take pics of? I have an A missing the starting crank and I plan on building one. Is the notch ramped on one side or is it square?
The Following User Says Thank You to pigpen60 For This Post:
Old 09-15-2019, 07:00:01 PM
dgibbs dgibbs is offline
Default Re: Briggs and Stratton "A" starting crank
Does this help. This is from a 1935 model.Click image for larger version
The Following 2 Users Say Thank You to dgibbs For This Post:
Old 09-16-2019, 12:33:49 PM
Yes, thank you. Now I just need to figure out how to make the ramp.
Old 09-16-2019, 04:02:00 PM
Flat to go against the starting pawl or pin whhen cranking, 45 degree cutaway so when the engine starts, the pawl or pin pushes the crank out of engagement. You can make it out of a section of pipe that fits loosely on the starter shaft, and cut the angled side with a thin angle grinder blade. Try to polish that ramp as best you can so the pawl does not snag.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Briggs and Stratton Twin 18 1/2 Cast Iron Bore "L" Head PhoenixRising2015 Small Air Cooled Gasoline Engines 2 07-31-2016 10:40:17 PM
Briggs & Stratton Motor Wheel powered "Hersey" Scooter barnhunter Unidentified Engines 4 12-27-2013 06:04:15 PM
Early Briggs Stratton "Y" with "X" in type number mschreiber Small Air Cooled Gasoline Engines 7 05-14-2012 09:33:34 PM
Briggs "b" bolt on starting handle questions. mschreiber Small Air Cooled Gasoline Engines 3 09-16-2011 10:25:57 PM
Briggs and Stratton Models "T" and "W" Tom Schaech Antique Engine Archives 0 10-13-2003 09:12:44 PM
