Need to ID this engine
this thread has 7 replies and has been viewed 399 times
Old 09-15-2019, 04:54:59 PM
Default Need to ID this engine
I have a Briggs engine I need to ID. I was told when I bought it that is a 7 hp engine.
Model # 140302
Type. # 0111-02
Code # 6506231 1965 ? or is this a serial number ?
I would like to know the size, year made and horsepower.
This engine is quite a bit bigger than a 5 hp engine.
Sorry, can't do a picture today.
Old 09-15-2019, 05:33:33 PM
Ogrebeast64 Ogrebeast64 is offline
Default Re: Need to ID this engine.
Originally Posted by EvilDr235 View Post
Model # 140302
Type. # 0111-02
Code # 6506231
Looks like it was manufactured on 06-23-65 by the code number. I've been on the Briggs site, and it has no listing for a 140302 model.
The Following User Says Thank You to Ogrebeast64 For This Post:
Old 09-15-2019, 06:14:53 PM
I'm sorta estimating by the model that it's a 6 hp. The 5 hp's are 130XXX model no.
The Following User Says Thank You to Pat Barrett For This Post:
Old 09-15-2019, 07:58:02 PM
gdstew gdstew is offline
140302 is a 14 cu in engine. Early ones were called 5.75hp, later 6hp
The Following User Says Thank You to gdstew For This Post:
Old 09-15-2019, 10:31:20 PM
K-Tron K-Tron is offline
I have not heard of the 140000 series either. I was aware of the 130000 series 13 cubic inch engines and the 170000 17 cubic inch engines but nothing in between. Please post a picture when you get a chance.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 09-15-2019, 11:38:40 PM
I found my Briggs & Stratton 1972 parts and service data book. It does list 140000 thru 140700 series engines. We have been remodeling and some of my books were packed away. I have seen on the internet a lot of lists that leave out the 140000 series engines probably because they are so old and not as common as some older Briggs engines. Thank you all for your replies and comments. I only recently got interested in the newer Briggs aluminum block engines. I also just found a 170000 series engine in the hoard last night while looking for a starter clutch. It is gold colored and has the remains of a water pump on the PTO shaft I need to remove. I need to get a proper camera so I can post pictures here, there and everywhere.
Old 09-16-2019, 07:43:13 AM
Bruce Dorsi Bruce Dorsi is offline
gdstew provided the correct information.
The Following User Says Thank You to Bruce Dorsi For This Post:
Old 09-16-2019, 09:00:34 AM
The 14 cu in engine was a "standard" used for years on Snapper riders and others. It was made both vertical and horizontal shaft and was a very popular engine in it's day. I'm somewhat surprised that it was left out of newer publications. It was a good motor and had a much better carb on it than the 5hp 13 cu in series
