Lauson 55s gasket and plug?
this thread has 3 replies and has been viewed 228 times
Old 09-17-2019, 10:51:47 PM
shiftlessguy shiftlessguy is offline
Default Lauson 55s gasket and plug?
Wondering what the oem gasket was for the 55.Mine had a composite gasket but i see a guy has a paper gasket fer 13 on ebay,which uf paper was oem I can make fer a lot less.Also plug fer same.It has a j6j rite now i think.I know briggs cast iron used paper and was mostly reusable but 55 has alum head cast block
Old 09-17-2019, 11:05:20 PM
K-Tron K-Tron is offline
Default Re: lauson 55s gasket and plug ?
If you have a caliper you can measure how thick your original gaskets are. I am not sure which gasket you are referring to on your 55. There are not many gaskets to begin with, their is a head gasket, ignition timing plate gasket and carburetor gasket. I do not think there are any others. I have two 55s but have never worked on them. The original gaskets might have been paper, fiber or asbestos. If you are concerned about the timing plate gasket, you should be. Too thick of a gasket and your crankshaft end play can become excessive. I make most of the gaskets for my old engines by matching thicknesses to the appropriate, paper/mylar/fiber or composite gasket material.
Chris
Old 09-18-2019, 08:56:57 AM
Partsman Partsman is offline
Card Sponsor
Hi I am a sponsor on this site. I have OEM gaskets for your engine. What do you need? Partsman Jim's Antique Small Engine Parts
Old 09-18-2019, 06:36:14 PM
Default Re: Lauson 55s gasket and plug?
Just wondering if oem was paper/asbestos or composite sandwich type gasket,and plug #
splitdorf spark plug anyone know what it would have been in very unusual plug Britstand Smokstak Down Under 6 09-04-2016 08:00:28 PM
Onan 5.5 bgm expansion plug freeze plug joenameplate Onan Generators 22 03-10-2013 02:59:20 PM
AC Spark Plug Div 4 Break Metal/Ceramic Plug? Bud Tierney Magnetos, Ignition Coils and Spark Plugs 3 01-08-2013 08:08:52 PM
Replacement Spark Plug for Maytag Uprights?? Modern Plug? enginesilo Maytag Engines and Collectibles 3 08-31-2008 01:21:57 AM
PERMATEX vs. paper gasket vs. other gasket material MarkP Small Air Cooled Gasoline Engines 1 04-19-2006 08:18:24 AM
