Need HELP with low compression on a Briggs Model WI
this thread has 3 replies and has been viewed 238 times
Old 09-18-2019, 01:03:17 PM
buckeyewalleye buckeyewalleye is offline
Default Need HELP with low compression on a Briggs Model WI
Hi Guys - I bought a Briggs model WI with no compression. I lapped the valves, cleaned the head, and poured about 3/4" of PB Blaster (4-5 times) in the cylinder and soaked it the to see if the rings were stuck. The PB Blaster SLOWLY drained down passed the rings and into the oil pan. Again, I did this 4-5 times with the PB Blaster and it drained down everytime. After that, I put oil in the cylinder and rubbed it all around the cylinder wall and I put it back together thinking the rings are not stuck. Now, I only have 30# of compression in the engine. Good news is that it's holding the 30#. What else can I do to get compression???
Thanks,
Scott
The Following User Says Thank You to buckeyewalleye For This Post:
Old 09-18-2019, 02:18:07 PM
Default Re: Need HELP with low compression on a Briggs Model WI
Unfortunately, PB will not always free stuck rings. It will not fix worn or broken ones either. If you have no gasses getting by the valves, there are 2 things you can do, but there is a question to ask first. Does the engine bounce back against the compression stroke? If it does, you can try belting the engine and turn it fast enough that it will start. Once the piston gets hot, the rings may free up, raising compression. If it just mushes to a stop, then you have no choice but to remove the piston and check out the rings. If they are stuck, free up and re-check compression. If free but worn, replace, hone the cylinder lightly, and re-assemble. If the cylinder is badly scored, you may have to bore and install an oversized piston and rings, if available. These engines dont have much compression to begin with - 50-60 PSI tops. It should at least to attempt at 30, unless it just mushes as I described earlier.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 09-18-2019, 03:37:34 PM
K-Tron K-Tron is offline
I never run a newly acquired engine that I have not pulled the piston out of. If the rings are stuck there is a good chance that they will do some damage when they free up under any form of load. Opening up the crankcase gives you the opportunity to clean out decades of sludge, check & access the condition of your rod and crankpin, and allows you to remove the piston to clean/remove the rings. With 30 psi of compression, either your rings are stuck, worn out or missing.
Chris
Old 09-18-2019, 08:58:55 PM
Motormowers's Avatar
Ring sets are cheap and you can make a pan gasket easily. I would say drop the base and pull the head again and remove the piston assy. If the rings are stuck just replace them. If not remove them from the piston and check end gap in the cylinder. Just a light hone and new rings will make a world of difference if the cylinder isnt wiped out.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Briggs and Stratton 6B-S Low Compression 57briggs6b-s Garden Tractors and Mowers 4 06-07-2018 08:01:29 AM
Briggs & Stratton Model N... no compression R Davis Garden Tractors and Mowers 22 02-01-2017 06:51:51 PM
Briggs 5hp low compression/won't run adman11 Small Air Cooled Gasoline Engines 11 01-29-2014 07:41:51 PM
Compression on Briggs 3.5? wfsdno Garden Tractors and Mowers 6 04-03-2009 08:45:56 PM
Briggs Model ZZ Compression Release Bill C. Small Air Cooled Gasoline Engines 2 11-07-2005 01:33:39 PM
