Briggs model 170432. Sorry, no pictures.
this thread has 0 replies and has been viewed 170 times
Old 09-18-2019, 09:52:23 PM
Default Briggs model 170432. Sorry, no pictures.
When I was working on my 140302 model Briggs I needed to find a starter clutch for it. While digging in my hoard I found a Briggs model 170432 in a dark corner of my shop. This is some information about it that some may find helpful.
Model # 170432= 17 cubic inches and 7 horsepower.
Type #1037-01
Code # 7206020 = 1972 model.
It had half of a unknown brand of water pump bolted to the backside of the block.
It has a 1-1/2 inch PTO shaft that has right hand threads to secure the impeller. PTO shaft is appox. 3-3/4 inches long. The end of the PTO shaft is reduced to one inch and is threaded 1-14 UNS. After looking closer, there appears to be a sleeve pressed on to the one inch shaft and has a key slot to lock it in place.
I had to drill several holes between the impeller and the PTO shaft to get the impeller off. No damage to the crank or threads.
It is a Easy spin engine.
Had a replaceable foam air filter at one time.
It does have good spark and good compression.
It is painted gold and had a rectangular fuel tank, now gone.
I have not tried to start it yet as the flywheel is rubbing on something when I spin it over. Will be pulling the blower housing.
The back removable cover has 8 bosses for mounting items.
3 bolt Flo-Jet carb.
2 fill plugs and 2 drain plugs.
After I run it and decide it is good enough to use, I will pickle it for future use.
Once again, sorry about no pictures.
Briggs 170432 Burning up Valves K-Tron Small Air Cooled Gasoline Engines 14 03-12-2016 01:40:45 AM
Briggs & Stratton Model MC pictures Dennis Wyatt Small Air Cooled Gasoline Engines 7 06-06-2010 01:50:09 PM
Briggs Model B Finished pictures Dennis Wyatt Small Air Cooled Gasoline Engines 12 11-22-2009 07:21:55 AM
Briggs Model FH Finished Pictures Dennis Wyatt Small Air Cooled Gasoline Engines 8 05-19-2009 05:28:56 PM
Briggs Model LA Finished Pictures Dennis Wyatt Small Air Cooled Gasoline Engines 6 04-22-2009 08:57:42 PM
