Steam Engines
Scale Models 1/4, 1/3, 1/2, ect
this thread has 388 replies and has been viewed 85372 times
Old 03-13-2012, 01:17:25 PM
Casemaker Casemaker is online now
Default Re: Scale Models 1/4, 1/3, 1/2, ect
more JD steamer
ID:	130932   Click image for larger version
The Following User Says Thank You to Casemaker For This Post:
Old 03-14-2012, 02:54:47 AM
Originally Posted by Casemaker View Post
hopfully attached will be the long awaited pictures of a Jeff Smith engine in its work clothes.....earning its keep running a cane press at a sorghum mill...I believe in N. Carolina..
Thank you Casemaker. If they want help removing the red paint I know a simple way..............it usually only takes one hurricane.
Jeff
The Following User Says Thank You to Jeff Smith For This Post:
  #283
Old 03-15-2012, 09:50:28 PM
http://www.forestryforum.com/board/i...html#msg774393
Jeff
The Following 2 Users Say Thank You to Jeff Smith For This Post:
  #284
Old 03-28-2012, 09:18:21 AM
here is pictures of a NS engine that sold at the Tony Brenda sale in Okla yesterday... it bought $2500
Name:	tony brenda ns 1.jpg
ID:	131945   Click image for larger version
Name:	tony brenda ns 2.jpg
Old 03-28-2012, 09:32:20 AM
Originally Posted by Jeff Smith View Post
here is more pictures of this engine being built.... the builder/owner is pictured and he built this in his shop class.... currently he is finishing up the threshing machine for it....
ID:	131947   Click image for larger version
The Following 2 Users Say Thank You to Casemaker For This Post:
  #286
Old 03-28-2012, 09:56:20 AM
Solid_Junk Solid_Junk is offline
Casemaker,
Based on the price of the Nick that just sold, the JD should be priced considerably lower in my opinion....
I believe we have met several years ago. You were cleaning up some family property, and I got some wheels and tires from a MM tractor from you if I'm not mistaken.
Joe
Old 03-28-2012, 10:18:56 AM
Joe,
yes.... the scrappers got that MM ZTU tractor before you got there...... I agree the JD steamer is too many unanswered questions for that price...maybe with it cleaned up and running it might be ok for the $8 k.
Old 03-29-2012, 12:28:24 PM
GYoung GYoung is offline
Question Re: Scale Models 1/4, 1/3, 1/2, ect
Originally Posted by Robert M View Post
I would like to see a thread with pictures of anyone that either has or has built a scale model, code and non code boilers. Over the years Ive seen many beautiful models that need to be enjoyed by all...
Don't mean to cut in, but since you are getting yourself into the middle of documenting scale models, but Please point me in the right direction . I need to know if Scale Traction Engines or raw castings are still available. If so From WHO and WHERE ?
If i don't get some sort of relief from this craving desire to want and build one (1/4 to 1/2 scale) I'll attempt to reinvent the wheel, and you know where that goes.
gyoung@twcny.rr.com
315-834-6995
Gene
Old 06-21-2012, 03:12:10 PM
oldiesteam's Avatar
oldiesteam oldiesteam is offline
I figure i need to jump on the band wagon and get my engine in the mix with the rest of the nice models. Here is a picture of my engine and the water wagon i just finished building over the winter.
Name:	Matts toy 2.jpg
The Following 4 Users Say Thank You to oldiesteam For This Post:
  #290
Old 07-19-2012, 07:37:29 PM
todd michel todd michel is offline
Grandkids on a fun run
Name:	tay and lievi.JPG
The Following 4 Users Say Thank You to todd michel For This Post:
  #291
Old 07-20-2012, 12:16:38 AM
butch vollmar butch vollmar is offline
I just wanted to show my two Universals.
Name:	6203 & 1264 5-30-12.JPG
The Following 11 Users Say Thank You to butch vollmar For This Post:
  #292
Old 01-26-2013, 11:51:52 PM
Nick S. Nick S. is offline
Ok scale makers. I have a question. Do you fudge any of the dimensions on your boilers to give you more heating surface area or do you just put as much flu area as possible. Any insight would be awesome!
Old 01-27-2013, 12:40:59 AM
It is best to use at least 1 inch tubes /flues personally, I try to lower the crown sheet /top of fire box to the half way position
as this gives more water space. Very nice if you are running on the ground keeps it covered more and put a larger door on get bigger wood in larger coal .
what scale are you thinking of building and what make
Todd
need spell check lmao
The Following User Says Thank You to todd michel For This Post:
  #294
Old 01-27-2013, 06:37:06 PM
Jamesk815 Jamesk815 is offline
Heres probably the finest park loco in the USA. It was built by
Augie Otto of Sandwich Il. and runs on 1000 feet of track at the Sandwich Fair every fall.Took 7yrs. to build weighs 9000 lbs.
The Following 3 Users Say Thank You to Jamesk815 For This Post:
  #295
Old 01-27-2013, 09:45:19 PM
3/4 ADVANCE 3/4 ADVANCE is offline
Hello Nick; I don't want to swat at a hornet's nest but here I go anyway. Some things do not scale well for practical use purposes. One thing is tubes / flues. A lot of scale size flues may not work as well as fewer, larger flues. The smaller the dia. of the tube the easier it will plug. Lots of models will "sit and smoke" and not be under a load for a lot of the time they are steamed up. Especially if you are burning coal, not having a load and the better airflow provided by the exhaust if you have a good smokebox seal can accelerate buildup in the tubes. A decrease in the ability to keep up pressure is a possible sign of this. A lot of engineers I know will not only punch the tubes in the morning but also again at lunchtime. I've lit the match, we'll sit back and see if I have managed to start another wildfire as the always welcome other opinions get voiced. That is, after all, how we all learn. Hope this helps, 3/4A
The Following 2 Users Say Thank You to 3/4 ADVANCE For This Post:
  #296
Old 01-27-2013, 09:56:54 PM
HalfKeck's Avatar
HalfKeck HalfKeck is offline
It is my opinion based on what I have seen that I would recommend using 2 inch flues. Your mileage may vary
160hp Keck: the search continues.....
The Following 2 Users Say Thank You to HalfKeck For This Post:
  #297
Old 01-27-2013, 10:13:33 PM
John Deck John Deck is offline
I would have to agree with Half Keck on the flue size. Terning used 2" flues in his scale engines and they will work well if you fire them correctly. If you try to use large pieces of wood they will not work. 2" x 2" aprox will work great all day long. 4 days of working on Butch Volmers saw mill at NTA this last summer proved it works.
John Deck
The Following 2 Users Say Thank You to John Deck For This Post:
  #298
Old 01-27-2013, 11:30:13 PM
I agree with halfkeck on the 2" and am happy with my boiler with them, but I would like to try 1-3/4" if I ever build something for my sons. I think there would be less heat loss up the stack because I could get more of them in the barrel. Some of the engine manufactures used them in their smaller engines.
Jeff
  #299
Old 01-28-2013, 08:08:41 AM
oldtractors's Avatar
John, I thought some of the Turnings had 1 3/4 tubes?
My vote is also 2" tubes. I wouldn't build one with smaller flues.
I have seen bad coal and wood plug even 2" tubes in just a couple of hours to the point that the engine wouldn't draft properly.
Jim Evans
The Following 2 Users Say Thank You to oldtractors For This Post:
  #300
Old 01-28-2013, 11:00:44 AM
Hi All; I am happy with the performance of the 2" flues / tubes in my boiler. I have also fired other engines with 2" flues / tubes and found them to be much more user friendly than an engine of comparable size but with 1 1/4" flues / tubes. I have run a 15" 4-4-0 loco with essentially the same boiler, and it would go all day long on the morning's cleaning. It was, however, pulling multiple coaches and climbing grades, which while hard on hats kept the I.D. pretty clean. The traction engine boiler was much more succeptable to buildup as it wasn't worked as hard. No matter what size they are, remember to keep scraps of O.S.B., particle board, and M.D.F.B. out of your firebox. They may seem like a good fire up supply since they burn easily, but boy that glue residue isn't good for heat transfer and can be a bear to scrape or brush out, especially after it has cooled and hardened. All for now, hope this helps, 3/4 A
The Following User Says Thank You to 3/4 ADVANCE For This Post:
Scale Models at Nowthen, MN '17 Nick Severson Scale Model Engineering 4 08-29-2017 10:05:12 PM
Scale Models -vs- Representations Jeff Smith Scale Model Engineering 7 01-25-2015 03:33:59 PM
Scale models / where are they now? Robert M Steam Stationary Engines, Traction Engines 22 07-18-2008 10:36:03 PM
Ihc Famous & R&v Scale Models Edwin Scale Model Engineering 1 01-02-2007 11:03:47 AM
Hartland Scale Models Wayne Lowdon Steam Stationary Engines, Traction Engines 5 02-28-2005 01:49:29 AM
